Motor mover problem
Impy
Impy Forum Participant Posts: 257 Participant
edited September 2024 in Parts & Accessories #1
When moving our caravan today we experienced an intermittent fault on one side of the caravan, at first it was fine, then one roller wouldn't engage, then it did, then it didn't etc., has anyone experienced this problem? any suggestions as to what the fault could be and how to rectify it? thanks.
    edited September 2024 #2
    I had a similar problem that was caused by a failure of some of the tiny plastic gears that drive the mover against the wheel.  Took a while to deduce it was not just the roller slipping. The epicyclic gearing is a marvel of miniturisation but unfortunately in plastic so replacement was only cure.
    Cornersteady Club Member Posts: 15,466
    edited September 2024 #3
    This once happened to us and it could be the battery in the remote - a simple change will tell you.
    Also where we store our caravan the local mobile mast interferes with the signal (a few have the same problem) and only cured by standing very near to the inside mover box. If it worked fine before and no new masts have been erected then it may be a mechanical breakdown or the battery.
  • Freddy55
    Freddy55 Club Member Posts: 2,007
    edited September 2024 #4
    This may or may not be helpful
    Powrtouch Reset
  • Impy
    edited September 2024 #5
     Thank you for your input/help/advice.  We will check your suggestions out tomorrow cool
