Vango Air Awning - Draft Gap - Help
Gordon Craig Powell
Gordon Craig Powell Forum Participant Posts: 54 Participant
edited October 2016 in Parts & Accessories #1
Have a Vango Kela air awning for the motorhome, I have a gap between the side of the motorhome and the awning sides that needs plugging, currently stuffing "stuff" in the gap...  gap is @ 6 inches at top to nothing at the wheel level. Could
do with an 6ft inflatable sausage of some form... any ideas?
Its not how we've fitted it, its just how it sits from the sun canopy attachment...
    edited October 2016 #2
     ,     i take it that you have a wind out awning on your vehicle  and your air awning atachesto the front of the box,?
    Have you thought of fitting a awning rail to the van wall which will then keep the awning flat to bodyside
  • Chris102
    Chris102 Forum Participant Posts: 84 Participant
    edited October 2016 #3
    At an awning exhibition earlier this year the Vango rep told me that the best way to fit a Keka  to the motorhome is to throw the long straps over the MH roof and peg down on the other side.
    He said that it gave the best fit.
  • Apperley
    edited October 2016 #4
    We found this an issue and have two solutions. We throw the throwover straps over the motor home and this pulls it tighter. We bought two extra storm straps and sewed the buckle onto the centre Velcro roof rail strap on the Vango so that we can also pull
    the middle tight too. But be careful you don't snag onto roof aerials or skylights. One chap we saw had tennis balls on strings to tie to the strap to make it easier to throw over.
    Also, we peg the tent door up against the van right next to the van and then turn the remainder of the tent out at 45 degree angle, but we still have a slight gap.
    We have seen other users who have attached a vertical pole inside a padded sleeve sewn onto the vango to try and pull this edge in, that seemed to work but a bit of a fuss.
  • Gordon Craig Powell
    edited October 2016 #5
    We were sat there yesterday looking at the side wondering why we couldn't just have a fitted awning on the side...
    But we have what we have... am on the search for plastic covered foam sheets that I can make a small panel out of to fit the gap, that would work... any ideas?
  • Apperley
    edited October 2016 #6
    This is another solution, dent pullers from e-bay, suction pad and a piece of velcro. Go to: http://forums.motorhomefacts.com/90-motorhome-awnings/180562-driveaway-awning-door-corridor-flappy-sides-2.html
     See the photos on page 2.
  • PrestonDave
    PrestonDave Forum Participant Posts: 67 Participant
    edited October 2016 #7
    We have a Vango Varkala caravan awning which has long foam pads down between the side of the van and the upright poles, maybe these are available as an extra fron Vango.
