Best way to cut a hole in floor of Gas Locker?
AlastairH
AlastairH Forum Participant Posts: 30 Participant
edited April 2016 in Caravan & Motorhome Chat #1
I intend to fit a refillable gas bottle in my MH and need to drill a hole in the floor of the gas locker to take the fill hose from the fill point on the skirt, through the floor and up to the gas bottle.
Does anyone have any suggestions as to how I can make a neat job inside and out of the hole and to prevent the hose from chafing where it passes through the opening?
    edited April 2016 #2
    Hole saw, drill so far from one side & if you can get to the other side, finish it of from there. How big a hole do you intend drilling? There area variety of grommits on eBay
  • richardandros
    richardandros Club Member Posts: 3,231
    edited April 2016 #3
    Assuming you're going through timber or similar, my preference would be for a Forstner bit because it usually gives a neater cut.  Either drill a pilot hole using a very small bit and then drill from top and bottom - or alternatively clamp or screw a piece
    of waste wood to the exit side and drill straight through.  This will prevent any 'ragginess' on the exit side.  Make good screw holes with waterproof filler.
  • volvoman9
    volvoman9 Forum Participant Posts: 1,053 Participant
    edited April 2016 #4
    I would use a holesaw for a job like this.They come in sets of different sizes and are cheap too buy.You could drill an oversized hole then lag the gas pipe with pipewrap where it goes through the hole.Again very cheap to buy and very easy to do.
    peter.
  • Metheven
    1,500 Likes 1000 Comments
    edited April 2016 #5
    I would use a hole saw with fine teeth, and obviously the hole will have to be much larger than the SS hose diameter to allow the threaded connection to pass through. I'd then shape and screw fix two semi circular wood pieces to reduce the hole to the actual
    pipe size after threading through, affix some rubber to the wood pieces before clamping tight to the braided pipe.
  • peegeenine
    edited April 2016 #6
    Have you considered mounting the filler inside the gas locker? It saves having to make holes in the bodywork and functions perfectly ok.
  • AlastairH
    edited April 2016 #7
    Thank you to all contributors.  Some good ideas there.
