Connection of a portable solar panel
Johnepu
Johnepu Forum Participant Posts: 3 Participant
edited July 2023 in Caravans #1
Can/should a portable 50/60W solar panel be connected to a caravan via pins 9 & 13 of the 13 pin euro plug using a 13 pin line socket?
These are the pins used to charge the battery when towing.
  • JollyKernow
    edited July 2023 #2
    I'm not sure why you want to use the 13 pin plug to install your solar panel? If your panel is portable (not fixed) then why not connect it directly to the leisure battery. You can easily procure what's called an Anderson connector which clamps to the battery terminals and leaves a snap connector with a male and female end to easily snap in when you are pitched.
    A bit more info with your thoughts would help John
    JK
  • Simon100
    500 Comments 100 Likes
    edited July 2023 #3
    Have you considered the need to put the solar panel charge through an MPPT or PWM controller to ensure  that the battery is not overcharged or discharges overnight?
    I think that you will also find that the guage of the cables used for the size panel you are considering are much greater that that used on the towbar electrics.
    peedee Forum Participant Trusted Posts: 10,120
    edited July 2023 #4
    I'm guessing it is a neat way of connecting the panel to the battery and I cannot think of any reason why it should not work other than there may be greater losses through the vans wiring and maybe the control panel compared to connecting direct to the battery.
    edited July 2023 #5
  • Johnepu
    edited July 2023 #6
    50W solar panel’s theoretical max output at 12V is 4.175A (3.6A at 14V). When tested for an hour on a sunny summer day with the panel at right angles to the sun, the battery voltage rose from 12.6V to 13.2V with a max current of 1.5A so presume in the UK max output is unlikely to be reached.
    The electrical loads on the plug/socket when towing could well be higher so overloading is unlikely. I hadn’t considered the cable size difference so thanks for that and I accept that electrical losses will be slightly higher through the caravan wiring. The solar panel does have a charge controller.
    For those with ATC - I don’t- connecting power to pins 9 & 13 may well liven it up.
    Cost for the two systems isn’t wildly different. Just thought that connecting to the euro plug was easier and wouldn’t need any extra cabling in an already tight battery locker.
    edited July 2023 #7
  • Johnepu
    edited July 2023 #8
    Thanks Young Thomas. The solar panel came with a second hand caravan. I’ll see how I get on with it before thinking of upgrading.
    I’d be interested to know how you charge electric bicycles off grid. Mine is 36V.
