Hi - problems with French Crit Air certificate
adelaidedalrymple
adelaidedalrymple Forum Participant Posts: 7 Participant
First trip abroad with new post Brexit rules and struggling to complete the cert-gov.fr form for emissions.
ok completing form upto the end and adding photo jpgs of V05 forks and Fiat engine plate. It responds ‘proof of registration…down …..’  jpg’s are 1mgb ish and can’t complete the form and pay
would appreciate any helpful comments thanks Gray/Adel
    edited June 2023 #2
    peedee Forum Participant Trusted Posts: 10,170
    edited June 2023 #3
    I don't recall having to send a photo of the engine plate? If you pics are jpg and under 2mbs it is difficult to see what your problem is. Have you confirmed the size of your pics by checking "properties"?
    DavidKlyne Club Member Posts: 14,893
    edited June 2023 #4
    If you are trying to upload directly from your phone I suspect that is the problem as most pictures I take on my phone are in the region of 4 MB. There is an App called Image Size that will reduce them. If doing it in pixels probably select a 1000 wide would make it small enough to be accepted. If you are using a Windows PC you could probably use the programs included in Windows.
    edited June 2023 #5
  • adelaidedalrymple
    edited June 2023 #6
    Thanks so far for suggestions will let you know how thing go.  Adel /Gray
  • Mother456
    Mother456 Forum Participant Posts: 5 Participant
    edited July 2023 #7
    I had trouble doing mine. You need a photo of your V5 document the inside page with all the car details on. Website kept saying photos were too big. So I took a photo emailed it to myself took a photo of the picture I sent and used this to fill in the form. Worked a treat crit air arrived a week later
  • TobyLeeds
    TobyLeeds Club Member Posts: 151
    edited July 2023 #8
    Hi
    have just done this and had similar problems first time. Then I saved my photo as PDF and uploaded that and it worked. The franch authority promises despatch in 7 days - we will see.
    edited July 2023 #9
  • adelaidedalrymple
    edited July 2023 #10
    Thanks so far everyone . Still on the quest after 7 day hol in Uk. From Chester area.
    I have Uk 2012 Fiat Adria motor home EURO 5 . VO5   Private light Goods
    An IPhone 13. Mini . 3.6 Mega pixel. + app suggested in discussion  ‘Image Size’ only 90% confident on its using it to reduce image size . Used it many way image size cms …etc with RED error in load message photO Also tried Screen prints .
    Will continue pursuing this immersions thing! !!?!!??
    Thanks all Graham and Adel
  • adelaidedalrymple
    edited July 2023 #11
    Oh No . Just tried screen shot 5.2Mb. disadvantage of new IPhone.  Back to seeing if I am using my ImageSize App correctly both to give A4 and 1Mb to  <2mb. Hey Hoe .
    G n A
    edited July 2023 #12
    Do you not have access to a PC or Laptop, either your own or perhaps a fried? Much easier task if you do.
  • adelaidedalrymple
    edited July 2023 #13
    Hi All still not sorted it,,
    I’m using image size app ;their website and their guide is too limited, I find it difficult to set required parameters for French site upload.
    I take a photo of Vo5 which is 3mb+ and has some edging ;
    I can photo edit out the edging. I can email it to myself at 1.5mb & save in photos. Then check photo as 1.5mb but cannot get the French form to accept it when uploaded.
    I have tried also ; then converting it to PDF via app and tried loading that. Without success.
    I have used French help email support on Saturday (tel no not working on W/E). And hope help may be available Monday.
    I suspect the French don’t like my French accent when speaking it on our much travelled journeys nor 2012 Fiat Adria camper !?!
    Thanks thus far - any comments still appreciated.will try PDF route again
    Graham and Adel
  • eurortraveller
    eurortraveller Club Member Posts: 7,342
    edited July 2023 #14
    Where are you going? Unless you intend driving into certain cities you really don’t need one. Give up the struggle.
  • adelaidedalrymple
    edited July 2023 #15
    D
  • adelaidedalrymple
    edited July 2023 #16
    Hi thanks one and all for your help.
    Got my email to confirm receipt of application from non government legitimate but more expensive website.
    learnt from guy who went to Paris by road for weekend that you can go into Paris Sat/Sun by car . Obviously getting income from punters more important than ‘crit air’
    thanks again Graham & Adelaide
  • jameslovescaravans
    jameslovescaravans Forum Participant Posts: 1 Participant
    Just came across this thread after having similar struggles with uploading my V5C. Resizing, screenshots, all the ideas above just wouldn't work. Maybe I'm just technologically inept.
    As above, I went with a different website (critairsticker.co.uk) which allowed me to upload my photo with no problems. I think the maximum size allowed was 20MB from memory. It was a simple ordering process, and lo and behold my Crit'Air sticker arrived fairly swiftly by email and then in the post.
    Just thought I'd to add to the last comment, that there are options if you're also struggling.
  • iansoady
    iansoady Club Member Posts: 420
    DON'T use that site. They charge you £20. The official site only charges €4.76. I've had no problems using it.
  • Wildwood
    Wildwood Club Member Posts: 3,854
    If you are stuck because the photo is too many megabytes, try taking it with a lot of excess around the information you want and then resizing down.
    Tinwheeler Forum Participant Trusted Posts: 24,419
    The points about posting photos refer to the old forum but we now have CT3 where posting photos is very much simpler.
  • ValDa
    For the future, just in case anyone doesn't know the official site, this is it https://www.certificat-air.gouv.fr/
