Water system bailey unicorn 2015
kazzyhutch
kazzyhutch Forum Participant Posts: 1 Participant
edited May 2023 in Caravans #1
Hi I wonder if anyone can help. My parents have a bailey unicorn 2015 caravan which they are currently away in. The water system suddenly stopped working mid way through their stay. They have replaced the whale pump and appropriate fuse and microswitch but are having no luck getting it up and running again. The pump makes a small humming sound then stops so obviously has power going to it. Any clues or advice?
  • Arch
    Arch Club Member Posts: 347
    edited May 2023 #2
    When the tap is turned on does the pump led on the control panel come and stay on if it does go outside and pull the pump out of the barrel you should hear the pump running it is running put it back and pull it up and down a few times making sure it's in the water if it's an air lock this will clear it, if on the other hand the led blinks on then straight off the pressure switch needs adjustment look in manual to see how, if the pump just hums briefly it could be jammed. Sorry for the long winded answer.
  • richardandros
    richardandros Club Member Posts: 3,195
    edited May 2023 #3
    The 2015 Unicorns have a pressurised system - no microswitch on taps - so it sounds to me that the pressure switch needs 'tweaking'. Instructions are in the manual. Don't ask me why - it doesn't seem logical - but we had this happen a few times in our previous Barcelona when the 240v supply was a bit low. How that affects the 12v supply via the battery, I can't tell you but I found that slight adjustment of the pressure switch solved the problem.
