Battery problems
Unknown
edited April 2023 in Parts & Accessories #1
    edited April 2023 #2
    edited April 2023 #3
  • mickysf
    edited April 2023 #4
    A word or two of caution. You need also to identify why the battery failed in the first place David or you may likely experience a repeat performance and another big bill. There are many reasons why a battery can fail like this but if it’s a charging issue, or lack of charging, once that battery level drops below the dreaded threshold it’s doomed. Hopefully, once discovered, it will be an easy and cheap solution.
  • eribaMotters
    edited April 2023 #5
    I've been trying to think back what my electrical engineer and production manager uncle said some while ago about a similar issue.
    He has a smart charger that in some instances can bring a dead battery back to life. Unfortunately when the battery is so low the smart charger cannot detect the battery and so cannot do it's magic. The solution is to use a normal charger that may be able to get a few volts into your battery. You can then swap it over to the smart charger as it will have something to detect.
    Colin
    edited April 2023 #6
