Water pumping out of hot water overflow
billandelaine
billandelaine Forum Participant Posts: 12 Participant
edited April 2022 in Caravans #1
Amazing that there is a thread on a very similar topic right now, but we've just returned from a trip to Devon with water flow problems except in this case, the water is pumping out of the hot water overflow! Block that, and the water flow from the taps, hot and cold, is fine!  But obviously not a long term solution. New taps were fitted last year so I doubt they are to blame. I'm mystified. Any thoughts?
    Cornersteady Club Member Posts: 15,476
    edited April 2022 #2
    Bit confused but what and where is the hot water overflow?
    edited April 2022 #3
    Well every day's a learning day, I've learnt something new. You mean the clear plastic tube past the drain valve? From what I've just read it means the valve has failed in some way and I've read either clean it to remove any limescale or it needs replacing.
    sorry I can't be more help but if you google your problem you might get more help or someone more technically minded than me on here (ie anyone) might be able to help.
    Post edit: someone said drain everything and start again and that might cure it?
  • billandelaine
    edited April 2022 #4
    Sorry, just to clarify, the water is coming out of the clear plastic tube that runs from the top of the Truma water heater - which I am guessing is a safety overflow that allows hot water to escape in the event of a blockage - rather than blow the heater up.....
    Have drained it and refilled, but no change. Can't see how it is anything to do with the drain valve, which is working fine, but limescale build-up - yes that could be it, she's quite an old girl our 'van......
