Advice regarding possible damp problem
ScreenName6F47E4B888
ScreenName6F47E4B888 Forum Participant Posts: 1 Participant
edited November 2021 in Caravans #1
Hi everyone,
I'm now at the end of my first season caravanning and in the process of getting my caravan ready for the winter.  When I was clearing out one of the lockers last Saturday, I noticed that the bottom of one of the struts felt damp to touch.  I had just washed the outside of the caravan so wondered if some water had somehow made its way into the locker, perhaps where the rim of the battery locker joins the van?  I've left the locker open all week and while it doesn't appear to have got any worse or spread further up the strut, it still feels damp to touch.  I've looked under the van and can't see any evidence of dampness underneath, however I'm concerned this could be the beginning of/ an indication of something more serious so wondered what others would do in this situation?  I've attached a couple of photos so you can see exactly what I'm talking about.
Thanks in advance,
John
  • eribaMotters
    eribaMotters Club Member Posts: 1,544
    edited November 2021 #2
    John, that is going to stay damp for a long time as air temperatures are low.  If it has not got any worse then my guess would be you've identified where the water got in. I'd be tempted to tape the offending joint to keep any rain out and then wait until next year when temperatures rise and you can safely play with a hose to soak things, knowing that you will be able to dry things out before attempting a reseal.
    The other alternative would be to spend a lot of money with a caravan engineer, if you can get one with a heated workshop who has a time slot.
    Colin
    edited November 2021 #3
    A couple of hours with a fan heater will aid drying out.
