Swift Command Engine Running
ijefferyes
ijefferyes Forum Participant Posts: 7 Participant
edited July 2021 in Caravans #1
I have recently bought a Swift Sprite Super Quattro and I wanted to ask a question about the command center.
I just had the car electrics upgraded to a 13pin, but as soon as I now connect the car to the caravan, the Command screen says Engine Running.
This message shows whether I have the engine running or not.
What it means is that I can't access the Power screen to see the current being provided by the car and I also can't access the settings to change the fridge.
Is this correct? Seems strange to me.
  • ijefferyes
    edited July 2021 #2
    Just found this in the Owner Handbook. Bit ambiguous, but does suggest I should only get this message once the engine is running rather than all the time.
    Anyone able to confirm for sure?
  • ijefferyes
    edited July 2021 #3
    Dealer have said this is normal, and as soon as you plug in the car, this is the message you get.
    Still seems a little strange, but will have to take their word for it.
  • Stewwroey
    Stewwroey Forum Participant Posts: 1 Participant
    edited September 2024 #4
    I'm having the same issue now then in the 2019 elegance, I after disconnect from car to get 12v working
