On board water tank not filling on my Lunar Delta
01sue
01sue Forum Participant Posts: 7 Participant
edited June 2021 in Caravans #1
Lunar delta ti, on board water tank not filling, any ideas welcome.
    Tinwheeler Forum Participant Trusted Posts: 24,312
    edited June 2021 #2
    Are you pumping it from a container using a submersible pump? If so, have you got the 12v feed to the pump turned on? Has the system worked previously?
  • 01sue
    edited June 2021 #3
    Hi , yes everything was good and it just stopped. we have replaced solenoid and  checked on board waterpump and everything checks out ok but not working.
    edited June 2021 #4
    If you are using a plug in submersible pump, I would suspect the fault lies with that. Otherwise, I’m afraid I’m out of ideas.
    edited June 2021 #5
    Any 12V fuses to check?
    There are mobile caravan engineers who will come out if you're on site.
  • 01sue
    edited June 2021 #6
    Thank you but that's fine . When pump on has power loss but can't find out where. Did have a caravan repair man look at it he said solenoid so we raplaced it . Out if ideas now. Thank you
  • Simon100
    500 Comments 100 Likes
    edited June 2021 #7
    Is there any chance that the water tank filling settings on the control panel have changed since the solenoid was replaced?
  • Simon100
    edited June 2021 #8
    Is there any chance that the tank filling settings on the control panel have changed since the solenoid was replaced.
  • 01sue
    edited June 2021 #9
    Hi, we know its a power problem but cant find out where. Probably have to go into a repair shop. Thank you
  • 01sue
    edited June 2021 #10
    Hi. after loads of checking we know its a power problem but finding it is a nightmare. Thank you anyway.
