Engine Battery Trickle Charger
Helens3050
Helens3050 Forum Participant Posts: 2 Participant
edited June 2021 in Motorhomes #1
I have a Peugot Boxer 1.9 and have sometimes had difficulty starting it when unused for a while.
I have used a trickle charger - but this year, when I went to use the van, the battery was dead.
I had it checked and am told the battery is fine and just needs to be run. Also, that the trickle charger I was using was of little use, if any. Can anyone recommend a suitable trickle charger?
Thank you
  • eribaMotters
    eribaMotters Club Member Posts: 1,513
    edited June 2021 #2
    CTEK are the default setting. They are an intelligent charger that you attach and leave. Many classic car owners use them as do car main dealers on showroom vehicles.
    Colin
  • Kasspa
    Kasspa Club Member Posts: 379
    edited June 2021 #3
    Some will say invest in a solar panel.... which can be linked to an onboard charger that deals with both cab & leisure batteries....
    If it is primarily for cab/engine depending on where you keep it & have power C-tek chargers/conditioners are excellent products.....
    I'm sure more learned folk will offer up alternatives!
  • LLM
    edited June 2021 #4
    Why not just use your EHU cable as if you are on site.  The onboard charger should keep your leisure and engine battery charged.  You may need a simple adaptor to enable you to use a 13 amp socket at home.
    peedee Club Member Posts: 10,073
    edited June 2021 #5
    Another vote for CTEK. I use one on a car which does not get much use.
    edited June 2021 #6
    from what I've picked up on this site, not all engine batteries are charged from the onboard charger
    edited June 2021 #7
  • NutsyH
    NutsyH Club Member Posts: 535
    edited June 2021 #8
    Another vote for CTEK. I have three in use - sports car which is sorned / garaged from 30.09 to 01.04 each year and starts first time; caravan when not hitched and battery never goes flat, 3rd one bought when Mrs Nutsy's car was sorned during lockdowns 1,2 &3 - again started first time.
    DavidKlyne Club Member Posts: 14,726
    edited June 2021 #9
    Helen
    I think we need a bit more information. Do you have a solar panel, if so, does it charge both  leisure battery and cab battery. If it does and you are still having a problem with the cab battery then its possible that the charge percentage to the cab battery needs increasing. As ED says above not all motorhome built in chargers send a charge to the cab battery. One way round this is to fit a device like a Battery Master which will push excess charge from the leisure battery to the cab battery. This will only be effective if you are able to connect the motorhome to the mains at home. However it will work from a solar panel.
    edited June 2021 #10
    edited June 2021 #11
    edited June 2021 #12
    I don't have access to it at the moment BB, its not an address I monitor when mobile. I wiil check it later.
  • Helens3050
    edited June 2021 #13
    Thanks for all the replies. Very helpful. We'll look into it further.
