Water pooling at front of caravan
Avantevans GT
Avantevans GT Forum Participant Posts: 2 Participant
edited November 2020 in Caravans #1
Hi - we’ve just purchased(Oct) a new Elldis Avante GT 550 and have noticed that the water collects at the front . I’ve lowered and raised the front to see if this helps but no.
It cant be good for the sealant around the roof lights.
Is this normal and nothing to be concerned about or should we contact the caravan manufacturer.....
thanks in advance for any feedback .
    edited November 2020 #2
    Your first contact should be your dealer  as they are responsible for warranty work   Elddis would  probably refer you back to them,
    edited November 2020 #3
    Most caravan/motorhome roofs have a degree of pooling as they are seldom "billiard table flat". Unless there is a significant undulation, tilting the van should solve the problem. When I had my caravan, I always put a substantial tilt to it during the winter when it was jacked up.
    edited November 2020 #4
  • crown green bowler
    crown green bowler Forum Participant Posts: 407 Participant
    100 Likes 100 Comments
    edited November 2020 #5
    Most van's have a raised strip across the front and back we're the roof is joined up to the front and back panels, some makes also have a raised awning rails which also can stop rain water coming off the sides. We had this problem with our last van which was an Elddis.  You may just have to live with it,  and tilt the van forward or back which ever  is best for you.
  • Tigi
    500 Comments 100 Likes
    edited November 2020 #6
    Ours has a slight natural inclination to the rear and offside due to the drive, otherwise pooling would occur.
  • Avantevans GT
    edited November 2020 #7
    Many thanks for all of your feedback - I called the dealer today and he too advised that it is common to see some pooling on the Elddis Avante and Buccaneer models. Don't worry was his words !
    I have got the van raised at the front but will raise some more to see if it makes any difference.
    It's brand new so will watch carefully and any internal issues and it will be straight in !
    Thanks again for your replies.
  • dave the rave
    edited November 2020 #8
    Maybe we should return to boat shape roofscool
    edited November 2020 #9
    It doesn't take much of a slope to shed water.
    edited November 2020 #10
    because my caravan is tilted down a  little at the back to help stop water pooling I get a load of green algae and general dirt down the rear offside corner of the van .... 😯
    edited November 2020 #11
    This is better than all across the roof!
  • Jazzybaby
    Jazzybaby Forum Participant Posts: 109 Participant
    edited November 2020 #12
    We used to have this problem also.  When on the drive at home we had the van tipped nose up. On a pitch however when it had rained, you always had to wary of when hitching up that you didn't get a curtain of water on top of you. Maybe its just an Elddis thing though cos none of our other 7 vans ever had a problem. The water collected around the stargazer roof light,
  • scoutman
    scoutman Club Member Posts: 460
    100 Likes 100 Comments Name Dropper
    edited November 2020 #13
    Water is a bit solid here at Pembrey this morning, brrr😂😂😂😂😂😂
  • Nuggy
    Nuggy Club Member Posts: 521
    edited November 2020 #14
    As others have said, I prefer to have the front of the van "nose down". This means that the rear corner legs are extended more, the rear legs have locks on them so IMO the "van" is harder to hitch up and steal, as well as clearing any water.
