Carver Cascade Rapide Water Heater
maggotymae
maggotymae Forum Participant Posts: 1 Participant
We have a 1993 Lunar Delta with a Carver Cascade Rapide water heater, does anyone know if this will just run off electric or does it need both gas and electric to work?  Thanks
    edited July 2020 #2
    It will run on electric only (if fitted) we hasve had one and  always have EHU on sites it just will take longer to heat up
  • rovinmad
    rovinmad Forum Participant Posts: 102 Participant
    edited July 2020 #3
    I did have one in the early nineties, but forgive me if my memory is a bit off.  You need 12volt electric supply to work the controller on the wall and fire up the gas.  If there is a mains element fitted it will have a 240 supply cable going to the hot tank and an on/off switch probably somewhere close. That's how I remember it anyway.  Mind you I'd be amazed if it all still works.
    Also I think there might be a reset button for if you switch it on with no water in the tank.
    I believe you can/could get a replacement  but I can't remember the make.
  • Pathfinder
    edited July 2020 #4
    Is it the GE model in which case it will work on gas or electric
