Motor homes and payloads
Jax1234
Jax1234 Forum Participant Posts: 3 Participant
Currently own a caravan but was looking at replacing with a 2nd hand motor home...BUT having decided on layout I am increasingly concerned at payload. It would be for 2 of us plus dog and 2 push bikes. Was looking at something like the Autotrail 632.( Liked the idea of fixed bed plus garage) Budget around £40k
I'm starting to get the impression that with a 3500 KG Gross Vehicle Weight this might not be possible. It's made even harder to work out as most of the dealer web sites don't give any indication of payload or MIRO. Any pointers or advice?
Thanks
«1
  • eurortraveller
    eurortraveller Club Member Posts: 7,297
    edited October 2019 #2
    If buying from a dealer ask him to weigh it as it stands on his forecourt,  add 200 kg for full load of fuel and water, then weigh yourself, your wife and your bikes and add all that too. What does it come to?
    DavidKlyne Club Member Posts: 14,821
    edited October 2019 #3
    I am sure BB will be along to give you chapter and verse on motorhome payload soon. When I was looking to change our previous motorhomes one unusual thing I noticed about Autotrail coachbuilt motorhomes (not van conversions) is that they appear only to have 60 litre fuel tanks(as opposed to the normal 90 litres), probably to save weight. On the surface payloads seem quite generous compared to caravans but when you have to take everything in one vehicle it becomes more critical. You need check the spec for the motorhome in question as usually they only allow 75kgs for the driver, maybe no water on board so if you want to carry a good supply of water, a passenger, dog, bikes it all eats into the available payload so you have to do your calculations. Depending on your age and licence it may be possible to up-plate the vehicle to say 3650 or higher but there are perils in doing this. Perhaps you need to cast your net wider in terms of models as you will certainly find some continental models with higher payloads, providing having the door on the other side is not a problem to you. We have recently changed to a different model Bailey motorhome which has a payload of around 750kgs which gives us a bit of leeway over our previous model.
  • Jax1234
    edited October 2019 #4
    Thanks both. I am surprised how little mention there is of payloads on a number of the dealer sites. I'm guessing 500kg would be about the minimum I'd get away with? (allowing for food/ crockery/ etc etc)
    Will try and find some continental models to look at
    edited October 2019 #5
    edited October 2019 #6
    I've got a Marquis Majestic 125 running at 3500Kg. Garage at back under a transverse fixed double. 6M long, so fairly compact. The Peugeot van is front heavy, so unless you travel with paving slabs for your outdoor space, it'll run at that weight.
  • derekcyril
    edited October 2019 #7
    After looking at alt the very good advice here ,i would keep my caravan
  • mickysf
    edited October 2019 #8
    Having been stopped by the police and escorted to a weigh bridge I have become far more weight conscious. We were just okay but the experience was not one I wish to repeat. The good thing mind was that we were issued with a free printout of the axel weights. Once home I weighed everything, including wife, that was removable from the van. At 1kg per litre I also had a gestimate for the water on board. As a result we had a real rethink about the essentials we carried and decided to adopt a light approach to packing for our tours. Quite surprising how much we carried which added very little to the enjoyment of our pastime. We now also only ever carry enough water on board when traveling for a couple of kettles.
    edited October 2019 #9
    Since our ten years of motor caravans and now back with towing a caravan,I have yet to  understand all the "negative?"worry about payloads of caravans, as the ever present go almost any where with no getting ready to move,support vehicle along side with  enough load capacity for all our long tour needscoolwink
    edited October 2019 #10
    edited October 2019 #11
  • Tammygirl
    Tammygirl Club Member Posts: 7,955
    edited October 2019 #12
    We had a Bailey 625se MH, never had a problem with the payload, we weighed everything the first time out, took it to weighbridge and still had plenty left. We had a full water tank but we never travelled with it full more like 40 ltrs. However some of the bigger vans of that make struggle to stay within the allowance.
  • MichaelT
    edited November 2019 #13
     It is not only payload but Axle weights you need to watch.  On our previous van we were within the payload when we had it weighed however we were very near to the 2000kg rear axle limit.  If we went up to the full 3850kg it may have tipped the rear axle over the limit and that was without bikes.  Not had the new van weighed yet as we have not been past the weighbridge which is 30 miles away but hoping to soon to get an idea of where we are but as we are now plated at 4500kg hoping we have plenty to spare even with 2 bikes in the garage now....
    edited November 2019 #14
  • Jax1234
    edited November 2019 #15
    Thanks everyone. Plenty to think about. Currently have a 6 berth twin axle caravan for the 2 of us and am starting to think I might just upgrade that. Will continue a search for a suitable motor home for the time being but not easy when most dealer sites don't even give an indication of pay load. There must be lots of people that get caught out with this.
    edited November 2019 #16
    So your payload   (as ours with your estate car)is above what  a lot of motor caravans can carry ,so how do you "understand"pooŕ payloads with as us all the payload of your carwink
    KjellNN Club Member Posts: 9,044
    edited November 2019 #17
    JVB, the point is that UK caravan payloads are notoriously low these days, and sometimes upgrades are not available or are only small.
    By the time you have added the battery etc and a Mover, the amount left for clothes, bedding, food and other essentials is totally inadequate, just ask TammyGirl!
    Not everyone wants to have to fill their car with so much stuff, especially when touring with maybe only 4 or 5 nights at each place.
    edited November 2019 #18
    The fact that you don’t understand the problem doesn’t mean that it does not exist, JV.
    edited November 2019 #19
    edited November 2019 #20
    I did not say it does not exist, but I would think that most who buy caravans, will look at what can be carriedundecided?and they as others have mentioned can carry a quite large payload in the tow vehicle,some caravans have quite large payloads but then they are already heavy, which in the uk market is not compatible with most owners tow vehicles
    edited November 2019 #21
    I think, with both caravans and MHs, that purchasers may not realise just how low the payloads often are, and dealers are not rushing to bring that fact to the attention of potential customers.
    A heavy caravan is not a problem for the correct tow vehicle, but if you have not researched your various weights properly before making a purchase, you can make a very expensive mistake!
    edited November 2019 #22
    I suspect that most first time purchasers will not realise the significance of 120 kg payload when 50 kg is taken by nover and battery etc
  • InaD
    InaD Club Member Posts: 1,900
    edited November 2019 #23
    Agree. When we had a motorhome and were looking at replacing it, payload was important.  Looking round, both at the NEC and individual dealers, questioning payloads was like asking for the impossible.  When asked, most dealers didn't even know the first thing about the payload for any given MH we were interested in.  OK, don't expect them to know everything about every single MH, but the reaction was always that "it will be fine".  Really?
    I do think that payload, whether for caravan or MH, is not as important to dealers as it should be, but then, being cynical, why should it be?  It's not in their interest.
    edited November 2019 #24
    Many caravans suffer from very low payloads but at least you can load the car up. As has been said many times on this forum, motorhome payloads can be a joke and certain manufacturers imply that you can get away with quite low payload such as 350kg. One “trick” is to give you a massive fresh water tank then tell you to only fill it to 20% for travelling. 120 litres is 120 kg which can slightly eat into your allowance!
    We travel very light - no bikes, no picnic table, tiny groundsheet etc. - and with a full water tank (but on a diet) we have 460kg.
  • Rocky 2 buckets
    Rocky 2 buckets Forum Participant Posts: 7,099 Participant
    edited November 2019 #25
    It is why a lot of folk are buying pickups, their payload is over 1.1tonnes.
  • rayjsj
    rayjsj Club Member Posts: 931
    250 Likes 500 Comments
    edited November 2019 #26
    Further to what David says, there is one Continental make that fits habitation doors on the UK kerbside. They are Benimar ( personally I think they all should. Having seen folk with children trying to get out of a motorhome in a layby in Scotland, with inches between them and a passing log lorry !) Another subject.
    Benimar look to be making good coachbuilt vans for the UK.
    edited November 2019 #27
    When asked, most dealers didn't even know the first thing about the payload for any given MH we were interested in. OK, don't expect them to know everything about every single MH...
    It's hardly difficult for any given MH to have the base axle weights available in its promotional brochures, from which prospective purchasers may do a bit of quick arithmetic to decide if there is sufficient payload for their requirements. As a rough guide I would think that any MH that quotes a payload below 500Kg should be viewed with suspicion.
  • Heethers
    edited December 2019 #28
    l have the Autotrail 625 Tribute high line, l had mine weighed on a weighbridge cost ten quid with all l need for a site pitch plus wind out awning and bike rack full tank of fuel 1/2 tank of water plus myself, less clothes and food it weighed 3.200 KG, l also had each axle weighed front and rear, the certificate is carried in the van. We have two electric bikes each weighing 25 KG each Golf clubs  2 sets 15 kg and two push trolleys 7 KG leaving 228 KG spare, more than enough left for food and other essentials. My Motorhome is 6.2 meters in length, my advice is to get the dealer to get it weighed empty, l think you will be surprised how much you will have. We had a caravan before we struggled to get the weight with having just 150kg to use, no chance with the bikes on board, hence changing to a motor home
    edited December 2019 #29
  • derekcyril
    edited December 2019 #30
    Isnt the most important thing to think about is the age thing ? 70
    edited December 2019 #31
    There are many things to think about in order to remain legal. Not exceeding the stipulated weights for the vehicle and having the correct driving licence entitlement being only two of them. Infringing these, as well as committing other breaches of the law, could land you in court and invalidate insurance so I’m not sure there is a 'most' important thing.
