Water pump problem
JontyWild
JontyWild Club Member Posts: 27
Name Dropper First Comment
Probably everyone knows this except me, but just in case!
We are away in our new (to us) caravan and the on board Ultraflow water pump refused to turn off and air was getting in to system. Went through all the possibilities: looked for leaks, inlet hose split or adrift from assembly. Checked the O rings were not split. Started worrying about the pump diaphragm, whole pump, non-return valve and how to get it fixed while away without buying expensive parts which may or may not fix the problem.  Decided to try a spare O ring on the intake hose assembly - cured!
Looking more closely, although intact the O rings are hard and have lost their elasticity and so are no longer sealing.  Off tomorrow to buy a replacement for the second one and some spares.
Out of curiosity, why have the manufacturers stopped fitting filters?
    edited August 2019 #2
    It might have an onboard filter just before the tank/pipes.
    edited August 2019 #3
    Why do you want a filter?
    The water on sites is perfectly safe to drink, just like at home, do you have a filter at home?
    A filter is just another expense, and can actually contain bacteria.
    You have not said which van you have.  We have Swift group van, and they have not fitted filters for at least 22 years.
    edited August 2019 #4
    Agree with Kj. Filters go green and gungy and need changing regularly at silly prices.
    edited August 2019 #5
    My 2013 Coachman has a carbon filter on the inlet or rather should have a filter but I removed it after seeing how much they are & how often it's suggested they should be replaced.
    edited August 2019 #6
    When we had a caravan with the carbon filter ,I was unable to get a real reason why it was needed in this country,when the water from a mains connected  tap did not require one at home, so as with many others I think, I removed it and just replaced the screw cap ,
  • allenmc
    allenmc Forum Participant Posts: 4 Participant
    edited August 2019 #7
    I have a bailey unicorn vigo, after the external water pipe has been on for the first time on the water barrel, when I come to fill the aqua roll for the second time the hose from the van to the roll wont come of. I have to put a screw driver on the side between the van and hose block turn it a little and pull. Any ideas ??
    edited August 2019 #8
    I find a little silicone spray applied to the fitting every so often helps it to fit on and off more easily
    edited August 2019 #9
    Is it the water pressure in the line that's the problem?  Try turning the pump off & then opening a tap to drop the pressure ... does the hose connector come off any easier?
  • allenmc
    edited August 2019 #10
    Have tried this still the same. Have taken back to marquis to rectify. Thanks any way.
    edited August 2019 #11
    I rarely need a second fill on site but when I do I never disconnect pump from caravan and instead just turn off the pump. When we are about to leave site I open the drain cock before disconnecting
