Truma water pump detaches from inlet when pump on
PennysOwner
PennysOwner Forum Participant Posts: 7 Participant
edited May 2019 in Caravans #1
The Truma ultraflow water pipe is being 'blown' out of its fitting when internal taps are switched on.
This is a very recent occurrence . The infeed pump detaches quite violently and on the last occasion broke the small plastic refraining lugs. Have checked seating, changed water filter and 'shaken' pump before switching on. Pump is inserted to water tank before connecting to van.
any help/advice gratefully received.
  • rjb
    rjb Forum Participant Posts: 117 Participant
    edited May 2019 #2
    Have you lost the small spring on the trigger under the body that holds it in
    Cornersteady Club Member Posts: 15,552
    edited May 2019 #3
    +1
    is it just me or they fiddly to fit and take off?
  • PennysOwner
    edited May 2019 #4
    Thanks for your response. Made me realise a couple of years ago I changes pumps, now have a Whale, comparable with the Truma fitting and has worked perfectly from new.
    As mentioned last event broke the Whale plastic retaining clips.
  • rjb
    edited May 2019 #5
    I spray it with thetford seal spray it helps
    edited May 2019 #6
    thank - will try that
