Water problems
JPOSH
JPOSH Forum Participant Posts: 131 Participant
edited March 2019 in Caravans #1
Hi
Just got on site
I cannot get pump to run
Truma sureflow I think
Van is a Coachman 575 vip 2015.
Tried a direct 12v feed onto external pump it runs fine
There is a flat topped round thing just inside
With battery feed +&- plus a lead to the pump
Bottom of it fits onto cold water feed.
Fuses OK
As pump starts for a second then cuts out
Any hell much appreciated
  • Merve
    edited March 2019 #2
    Hi JPOSH, it sounds like the 12v line is breaking down somewhere- probably due to corrosion or a bad connection. The pump is OK as you know. The Fuse is OK- A multi meter to check voltage may assist finding where the fault is. We don’t all carry multi meters though! I am about to pick up my New Coachman 575 so I’d be interested in any solutions found!
  • commeyras
    edited March 2019 #3
    I had a similar problem last year.  Found that it was a little corrosion on the contacts.  A good clean with sand paper, a spray with WD40 and bending  the contacts slightly with pliers to improve the contact did the trick.  Also ensure pump is securely locked in position to caravan, it might just be slipping out and readjust the pressure control - your handbook should tell you how to do this simple operation.
  • JPOSH
    edited March 2019 #4
    Hi all
    Had a good look about this morning
    I can pull a12v  feed off the truma smart switch then re-attach and pump runs for a second or two then cuts out again.
    Faulty smart switch?
    edited March 2019 #5
    I came across this post which might be worthwhile checking said connection.
    https://www.caravantalk.co.uk/community/topic/108859-intermittent-water-pump/
  • JPOSH
    edited March 2019 #6
    Hi all
    it seems like the smart pressure switch has packed in
    Spoke to a caravan technician who then spoke to truma and they've not really heard of one packing in. So hopefully £60 odd will sort it
    Less than a 5 minute job, very easy
    edited March 2019 #7
    Surprising that they are so readily available then wink
