Ebike battery charging using inverter
scouter66
Forum Participant Posts: 2 Participant
We currently have a 1000w inverter on our MH which generally copes with all our off grid needs. However having recently purchased an e bike the battery will not charge on the inverter. I am not sure if the inverter is too small & simply overloading or if there is an inherent problem with inverters charging this type of battery.
Does anyone use an inverter to charge their e bikes. I would like a bit of clarity before I simply go out and buy a larger inverter. Thanks.
