Blue fresh water outlet tap
mg55
mg55 Forum Participant Posts: 24 Participant
edited November 2018 in Motorhomes #1
Hello,
our blue drain tap is stuck in part open position resulting in a slow loss of fresh water. We cannot close  it completely and we’re wondering how easy it is to replace the tap. The pipe work is fine.
    edited November 2018 #2
    Depends what type and position ?a bit more info might get a better responsesurprised
  • mg55
    edited November 2018 #3
    Thank you, will post picture tomorrow as too dark outside to take photo.
    Tinwheeler Forum Participant Trusted Posts: 24,324
    edited November 2018 #4
    MG55, most blue or grey drain taps simply clip into the holding bracket and are a push fit on to the pipe. MH plumbing pipes are normally push fit and not fixed or stuck in any way.
  • mg55
    edited November 2018 #5
    Thank you Tinwheeler.
    edited November 2018 #6
    You're welcome. Hope it helps.
    You can usually buy new drain taps in MH/caravan accessory shops if yours is beyond help.
    peedee Forum Participant Trusted Posts: 10,113
    edited November 2018 #7
    I have just had to replace a drain tap. Got the replacement from >CAK Tanks<
  • mg55
    edited November 2018 #8
    Thank you Peedee, that’s really useful.  Hope it’s easy to fit!!
    edited November 2018 #9
    Easy to fit to pipes but not that easy to access under the motorhome but that could just be the way mine was mounted.
