Broken lock on door to Thetford Cassette
DerbyshireBob
DerbyshireBob Forum Participant Posts: 12 Participant
edited May 2018 in Caravans #1
I have a Bailey 460-2 year 2000 The door to the Thetford Cassette no longer locks.The model is C-200 CW/CWE. Does anyone know if the lock is repairable, or am I going to have to purchase a new door.
    edited May 2018 #2
    fleebay.
    DavidKlyne Club Member Posts: 14,574
    edited May 2018 #3
    What is the manner of it "not locking"? Is the barrel of the lock just rotating? Have you removed the lock? If you do be very care when undoing the inside part of the lock as there could be springs that could pop out. Bailey have a very comprehensive parts service although whether they go back to 2000 I don't know.
    Here are a couple of other links E-Bay and Leisureshop which might be useful.
    edited May 2018 #4
    As Dave says above .... what's not locking? On my last caravan the lock worked but the part of the frame that the latch locked behind had broken.
  • PickledOnion2
    PickledOnion2 Forum Participant Posts: 8 Participant
    edited May 2018 #5
    The lock is a fairly simple unit and it's very likely that you will be able to purchase what you need from the links David has kindly added. Go to the Leisureshop web site then Thetford, select toilet section and then Service doors, this should guide you through to the correct exploded diagram of the lock and it's associated parts.
    Dave.
