Solar panel !!! Help and advice needed
chasstreet
chasstreet Forum Participant Posts: 57 Participant
edited May 2018 in Caravans #1
recently had a solar panel fitted to our bailey. Truma 65w
all was well until this weekend.
“Check voltage” message kept (5 timesin 2 days) appeared on the whale control screen.
Looking into this seems that the battery was @15.4v and system had shut off all power to protect.
Was Only happening in strong sunlite, so I disconnected the solar panel. This seems to have at least stopped the message reappearing
Anyone with ideas ????
I have checked all connections, so can only surmise it’s the Truma solar controller
    edited May 2018 #2
    Sounds most probable. Get back to your supplier.
    edited May 2018 #3
  • Oneputt
    Oneputt Club Member Posts: 9,215
    edited May 2018 #4
    My 100 watt sits at about 13.7v
    edited May 2018 #5
    max should be approx. 14.6/14.7 so as said would check controller.
    edited May 2018 #6
  •  viatorem
    edited May 2018 #7
    If it is an SDC 10 you might want to check what type of battery it is set to Gel, AGM, or Liquid. My factory fitted unit was set to Gel which is the lowest voltage setting presumably to avoid gassing when connected to a liquid battery. I also see that the maximum voltage of the SDC10 is 16.6v which I guess is for very flat batteries.
    https://www.truma.com/web/downloadcenter/files/truma-miscellaneous-sdc10-sdc20-installation-operating-de-en-fr-it.pdf
  • Merve
    edited May 2018 #8
    I would suspect the controller first. Sounds like it’s continuing to pump power into the battery and not cutting off when it should. Be interested in knowing what you find out!!
  • AJMJ
    AJMJ Forum Participant Posts: 7 Participant
    edited June 2018 #9
    I'd also be interested as our solar panel led lights 'flash' but sometimes are static and I haven't a clue what I should do about it.
  • Boff
    edited June 2018 #10
    Normally the Led light on the controller flash when the battery is full.  A solid light means the battery is taking charge.   If you see the light flashing, try switching everything on to see if you can drop the battery voltage you may find the light goes solid.  Nothing to worry about, I suspect.
  • AJMJ
    edited June 2018 #11
    Boff, thank you, you've set my mind at rest.  I kept wondering what the problem was.  AJMJ
  • chasstreet
    edited June 2018 #12
    Thanks everyone
    spoke to Truma
    they sent controller that arrived 2 days later
    all good now
    flashing light =battery charged
    solid green light =battery is charging
