Truma blown air problem
bowleggs1
bowleggs1 Forum Participant Posts: 9 Participant
edited March 2018 in Parts & Accessories #1
Please can anyone help me with my truma blown air problem it will not blow warm air out the fan works ok on all three settings but no warm air has anyone got any idea what the fault my might be have replaced fuses in the electrical switch but still no warm air on 240 volt
  • ATB
    ATB Club Member Posts: 5
    edited March 2018 #2
    There are two over temperature thermostats at the back of the heater and their contacts can disintegrate, which is what happened to mine. It’s not advisable to dismantle the heater yourself as it requires the gas and flue outlet connections to be disconnected. I had mine repaired at my local caravan repair centre, it cost about £80 but well worth it knowing the repair was carried out by a competent person.
  • Bakers2
    Bakers2 Forum Participant Trusted Posts: 8,623
    edited March 2018 #3
    Stating the obvious 😲. Are the tubes connected to the back of the fire and the outlets?
  • Vicmallows
    edited March 2018 #4
    Assuming we are talking about a Trauma S3002 fire + Ultraheat........
    Does the green light in the control knob/switch come on.   If not, you do not have 240v to the heater …..or the transformer on the control PCB has failed.
    If the green light is on, then most likely it is either the over temperature limit switches as already mentioned,  or equally likely the relays on the control PCB which are notorious for failing.   If it is one or more of the 3 relays, a very common failure mode is that it will only work on the 500W setting. .....and it takes a long time before you can feel it producing heat at all.
     The relays and transformer are cheap standard items and can be readily replaced if you know what you are doing. Alternatively EBay advertisers offer refurbished exchange boards.
  • Vicmallows
    edited March 2018 #5
    Truma.   tongue-outtongue-out
    edited March 2018 #6
    I take it you have used it on 240v  before.? and had warm air,
    The 240v was not a standard fit on some vehicles
  • bowleggs1
    edited March 2018 #7
    Sorry but I am an idiot it's a whale blown air system on a Bailey Orion any ideas would still be a help checked both 12 volt and 240 volt fuses all seems ok, fan works on all three settings but no warm air on 240 volt no flashing red lights to tell me any system faults any ideas would be extremely welcome
