Lunar internal light problem
Psmiffy
Psmiffy Forum Participant Posts: 26 Participant
edited February 2018 in Caravans #1
Hi folks, I'm getting our 2016 Conquest CK ready for a trip, and found two of the reading lights over the settee are just a faint glow. (They're the non changeable bulb type)Also a main roof light in the van isn't working at all. It was all working at Christmas when we last used the van, and everything else including other lighting works fine. I don't understand how the reading lights can just glow slightly. If there was a break in a circuit they wouldn't work at all.I assume the light not working and the two faint ones are connected in some way. The battery is fully charged. It's a long round trip to the dealer so your thoughts and suggestions will be most welcome.
Thanks
Paul
    edited February 2018 #2
    My first question would be 'are you sure that the battery is fully charged and holding its charge? How do you know that? Are you sure that the battery has not gone duff?
  • jennyc
    edited February 2018 #3
    A clean break in a wire, will, as you say, prevent current from flowing, but a poor connection caused by corrosion (oxidisation)  or a lose contact, may prevent the required current (amps) from flowing. Think how a partially sink waste pipe will reduce the water flow, so that it drains slowly.
    The above restriction may exist somewhere in the +ve feed which is shared by all three lamps, or on the -ve, which is also shared. Your large light may well be glowing, but so faintly due to reduced current, that’s not noticeable.
    Locating the fault is likely to be difficult with a voltmeter because it may register 12 volts, despite the limited current flow. Testing is best achieved with a real bulb connected to two separated bits of wire. Connect one wire to any known to be working point on the -ve supply. Use the battery -ve if necessary, then check whether your improvised test bulb lights properly when you touch the live feed to your switch if it does, then the fault lies in the van’s -ve return circuit. If the bulb doesn’t light properly, then the fault is in the +ve feed. Whichever half of the circuit has been found defective, you then need to bypass lengths of it with your home made tester until you have bypassed the fault. Using the tester in this way, will reduce the intensity of the bulbs glow because the bulbs will be connected in series. BUT, it will serve to save you from inadvertently blowing fuses by touching the wrong wire.
    If the above is double Dutch to you, then you might be safer getting someone with more experience of working with electricity to help. Motor mechanics are notorious for their inability to understand electrical circuits, so when you’ve found one that does, make an indelible note of his contact details.
    Good luck.
  • Psmiffy
    edited February 2018 #4
    Hello Easy T the battery is almost new and showing 13.6volts the van is hooked up to mains. As in op everything else is working perfectly the fault is just showing on these lights alone.
    P
    edited February 2018 #5
    Certainly sounds like a poor connection in the wiring. I had something similar on previous Lunar affecting some lights towards the front. Seemed likely to be a poor connection as the fault was intermittent. Arrive on one site and a couple of lights not working. Arrive on next and everything worked etc. Turned out to be a poor connection hidden beneath the microwave.
  • Psmiffy
    edited February 2018 #6
    Ok thanks for the replies. I'll get probing, though it's  not something that can't  be lived with. If I  get stuck it might have to wait till service time. I'll report back,
    Cheers, Paul
    edited February 2018 #7
    I have tended to use the unscientific wangling method. smile
    I have waggled (or should that be wiggled?) wiring about until a light flickers to narrow down/locate such problems.
  • JohnM20
    edited February 2018 #8
    I have a 2015 Lunar Quasar 524 derivative (dealer special). Since new I have had an intermittent fault with the two centre ceiling lights. Sometimes they work and sometimes they don't. It is always both, not just one of them. Sometimes they are OK when I set off on a journey but have failed upon arrival. At other times it is the other way round. Sometimes, though, if they are in the failed state, if I leave them switched on they will suddenly come on after several minutes. I have been told that it would be a very lengthy job to try to find the source of the problem which might, I'm told, involve taking the ceiling panelling down. For the number of times we use the lights I've decided to leave things as they are as I didn't want to be without the caravan for an indeterminate length of time.
    It's interesting that others have a similar problem with their Lunar. If anyone can pinpoint where the fault probably lies I'd be keen to know. Is it just a Lunar issue?
    edited February 2018 #9
     I suspect that most joints are accessible somewhere rather than hidden in the ceiling. In my case it meant removing the microwave.
    edited February 2018 #10
    I have one light in lounge and one in bedroom not working and tested by swapping complete lights with one that work. pointed out to lunar at service that its a wiring fault but stated that its not covered after first 12 months. ridiculous. tried to sell me a new shower light at £65 and a front nearside road light as a bit dim. removed myself, cleaned and ok. took 5 mins. I think Campbell's engineers a bit DIM.
  • Hoddy
    Hoddy Club Member Posts: 34
    edited February 2018 #11
    I had the same on one of my LED downlights (Lunar Ultima 560) checked the wiring near the lamp and found a bad connection. Sorted this out and light works perfect.
  • lagerorwine
    lagerorwine Club Member Posts: 312
    edited February 2018 #12
    Campbells might be a bit dim, but the black greasy handprints left at first service on our cream interior weren't. Never mind, a bit of rag and some brake cleaner did the job after we pointed them out!
    As you can imagine, 2nd and subsequent services conducted elsewhere.
  • Psmiffy
    edited February 2018 #13
    Update.......as suggested by the very helpful replies I  wiggled wires,fuses etc here and there and checked battery neg and pos connections etc. It's down to dodgy connections somewhere between the fitting itself and the wiring after it has disappeared out of reach. I unscrewed each of the downlights and when moving the fitting and wires around they sometimes work and sometimes don't. The connections at the fitting are all sealed and the wires disappear into holes in the paneling.The frustrating thing is I had one working and when I screwed it back in place it stopped again. Anyway all is now working and I will just see what happens. I assume if it keeps happening it should be covered under the warranty.Thanks again for all the help
    Paul
  • Tigi
    500 Comments 100 Likes
    edited February 2018 #14
    I`ve had an LED Strip on the underside of a cupboard go dim and in my current van one of the corner cubes is not working correctly both Lunars. We soon changing so will let dealer sort out.
    If the fault is due to poor connections i.e. workmanship and that is accepted the repair should fall within the warranty, the year applies to the bulb failure?
  • High32
    High32 Forum Participant Posts: 1 Participant
    edited September 2021 #15
    I have 7 years old lunar lexon 560  just bought and noticed the kitchen bulkhead led and one of the corner led's are not working. I find it astonishing that these are "not replacable", we all know by now that contrary to popular myth, led's do not by any means last forever. In fact I  have had led bulbs that did not last as long as conventional bulbs, given where they are manufactured this should be no surprise.
    I will check out the connections etc but I suspect that 7 years is a reasonable design life for any electronic component. On my car I have had indicator   led's  that have gone within 4 years.
    I have sourced come similar led units on line although I am not sure yet how these would be fixed as the originals appear to be hard wired in. I am  some what  aggreived  given that this appears to be such  a common problem that a quick fix is not available to caravan owners. Obviously this will be an ongoing problem for older caravans and it would appear that no one has bothered to come up with an easy and cheap solution. Even the dealer I bought the caravan from could not offer any help.
    Someone please tell me I am wrong.
    Ian.
