Fresh Water Solutions
BSB Tourers
BSB Tourers Forum Participant Posts: 2 Participant
edited January 2018 in Motorhomes #1
We are brand new newbies and looking forward to our first ever motorhome trip in March.
We'd like to pick experienced brains about fresh water carriers please.  We started out looking at a 40 litre Aquaroll but think it might be too bulky as we have nowhere really on board to store it.  The Fiamma 23 litre looks more compact but might be too small.  And to get water from the carrier into the onboard tank we seem to need some kind of submersible pump but can't see if the smaller carriers are compatible with this, or what additional pipes, connectors or kits might be needed to go with it.
Any advice gratefully received.  Hope these aren't stupid questions but you've got to start somewhere!
«1
    edited January 2018 #2
  • ABM
    edited January 2018 #3
    Not  sure  how   " Brand New"  you  are  BSB,  but  filling  the  water  tanks  from  dry,  as  I  assume  you  will  be,  You  can  use  a  length  of  plastic  food grade  pipe  &  a  tap  connector  as  BoleroB  said.  This  will  allow  you  to  use  one  of  the  "Service Points"  on Club  &  most  other  sites.
    After  pitching  on  your  chosen  area  of  the  site,  only  then  will  you  need  the  use  of  a  mobile  water  carrier. Mine  is  a  bright  red  watering  can  of  2.5  gallon,  which  is  enough  for  my  needs  both  in  the  'topping up'  department  &  in  the  'physical  exercise'  bit  as  well.  the  use  of  the  watering  can  would  allow you  to  top  the  empty  tank  with  a  few  gallons  to  give  you  'Services as  Required'  on  your  first  journey.
    edited January 2018 #4
    We always fill the on board tank directly from the tap and the only water container we carry is a 5 litre one for drinking water.
    MHs lend themselves to being moved and it's no effort to fill at a service point as you pass.
    Tip - club sites (not necessarily CLs) have dedicated MH service points where you can fill and empty. Please use these points if they exist rather than blocking the ordinary service points which prevents others from using them. Thanks.
    edited January 2018 #5
    When you say you may need a submersible pump, what sort of inlet have you got on your motor caravan,?
    edited January 2018 #6
    Or as noted today a queue of three arriving motor caravans at a normal service point,completely blocking the one way system,as another motor caravan had blocked the MV service point,on the way out as he decided to have a shower while his waste tank dribbled awaysurprisedyell
    edited January 2018 #7
    It’s all about consideration for others, JV.
  • brue
    edited January 2018 #8
    I seem to remember the FM M/H point on the west side was in an awkward spot, it will be good when the club makes things easier. smile
    We take a 20L container to fill with top up water and a lightweight fold up trolley in case it's a long walk to a water point. You can get fold up/collapsible containers too. I think there is a fold up silicone watering can, might be useful for some.
    DavidKlyne Club Member Posts: 14,726
    edited January 2018 #9
    The problem with the Fiamma and using it with a submersible pump is that the hose of the pump might not be long enough. The Fiamma 23 lt water tank is really designed to be used in a caravan as dedicated inboard water tank. Many European caravans have a special hatch where it fits. Might be useful to mention the make and model of motorhome you have. Our Bailey uses the Whale system and we still use our Aquaroll to replenish our onboard tank especially if we are staying on site for three or more days.BTW we keep it in the shower during transit.
    edited January 2018 #10
    About to start our third year with the Motorhome after 30 odd years of Caravan and I just ditched the 10 litre water carrier because we have never used it and I wanted to save space. For drinking we use mineral water bottles which we refill direct from the tap or if on the continent we often drink mineral water.
    With 100 litre fresh water tank I fill up upon arrival at site using the service point and hose and this is good enough for several days. If we stay for a long period then the chances are we will need a big supermarket shop so have to go off site which is when we would refill if needed.
    For waste, if we are near to a convenient disposal point we use a bucket under the outlet hose and empty when full. We have found it better to empty the waste frequently to prevent build up of smells. On a CL you can often dispose of waste water in the hedgerows provided it is not contaminated with food, cooking oil etc. Take the advice of the proprietor if in doubt.
  • brue
    edited January 2018 #11
    We always fill up at home and we take a largish container as we're not always on club sites, for rallies etc we need to use top ups. We use a bucket too for the waste water but both the tanks last quite well if needed.
    edited January 2018 #12
    As i may have posted before it is not the MV service points on sites that are main problem, it is the extremely poor design and position of the outlets ,on both our motor caravans it cost about £10 to modify the outlets into user friendly discharge, that could and should have been as built,rather than expecting the leisure industry to spend thousands of pounds to cater for poor design of LVs
  • Takethedogalong
    Takethedogalong Forum Participant Trusted Posts: 18,300
    edited January 2018 #13
    All we have in MH is a hosepipe, a bucket (multi purpose) and a small collapsible water carrier. Fill up at home, top up on sites as we go out and about, empty similar, or bucket/ pipe waste Grey waste ( nearly all shower/ handwash) into hedgerow with owner permission. So easy.......
  • brue
    edited January 2018 #14
    JVB. Bring on those open grids, that would solve it for most. wink
    edit....in an easy access spot.
    edited January 2018 #15
    Why? As i said in my post,when its poor motor caravan  design that is the real problem
    edited January 2018 #16
    The original design of motorhome waste points employed on Club sites is awful. Fortunately they are actually changing them to full width open grills which makes it easy for all motorhomes to dump waste water whether the water drains for offside, nearside or central. I am not suggesting that motorhome waste taps are perfect, far from it but at the end of the day it is the design of the site facility that makes the biggest difference.
  • eurortraveller
    eurortraveller Club Member Posts: 7,264
    edited January 2018 #17
    BSB Tourers, I don't think I have ever seen any motorhomers  in Europe with an aquaroll for fresh water. They fill their on board tank from a hosepipe or from whatever watering can or portable water carrier they have with them - as we do with our small caravan. I don't want to cart an aquaroll around for fresh water. Do you?
  • Takethedogalong
    edited January 2018 #18
    Agree DK. Our MH drain isn't bad anyway, at the rear, our MH is possibly a tad higher than more modern ones. The MH waste point at Warwick Site is a shocker, even we, with our little 5.5 metre job had to shuffle, and there was a lot of damage visible to adjacent posts and fencing, so I am guessing others have had worse problems than us.
    edited January 2018 #19
    ET
    Some of us do and it proves quite handy for longer stays.
    edited January 2018 #20
    We were at Chatsworth in early December and in order to position the waste point over the drain I had to park across the adjacent pitch. I did note that in both the review I wrote and the survey that the CMC sent after the visit. I accept at 7.5 mts long we have a slightly larger motorhome than many but you do get the impression that motorhome waste points were an afterthought. I know the Club are addressing this but it seems a very slow process.
    edited January 2018 #21
    JV, I have to disagree. While I don't doubt that the outlet design on MHs could be improved, the design and layout of club (both clubs) MHSPs is truly appalling.
    Who's bright idea was it to install manhole covers that weigh a ton and bend when they're driven over so they jam? And who thought that only having a couple of choices of where to be able to drain into said square holes rather than a long grid was clever? Whoever thought it was a great idea to angle the ends of the service bays so there's insufficient room to manoeuvre even a modest sized MH? I'll tell you who - someone who's never used a MH in a true life situation.
    Believe me, if I could overcome these problems for the sake of spending a mere £10 I'd be very happy. It beats me how you cannot see the problems lie with the design of the MHSPs.
  • Takethedogalong
    edited January 2018 #22
    We visited one of the newest sites on the network a couple of years ago, Barnard Castle. I can't recall what the actual drain was like, but guessing one of the lift the lid types. I do recall we had to drive out of the site, and then back in through the barrier to just get to the waste point from our pitch. (We were actually leaving, after our one night stay) I honestly don't think that the Club saw the MH phenomenon arriving, it was like the Magic Roundabout with MHs circling the site!
    edited January 2018 #23
    So perhaps the caravan Club should try to get ahead of the game and install fully fully fully serviced pitches that each consist of a 8m long grid so that all caravans ( trailer, motor, battery, solar, unicorn fatr powered ) can dump out waste wherever the maker put the outlet.
    Or perhaps they could exert influence on the manufacturers to position the outlets in a standard location, and to make them fit for purpose in terms of size and accessibility.
    Now, which idea above do you think is the more fanciefull?
    edited January 2018 #24
    Site facilities are having to be altered because of poor design of motor caravan waste outlets,  it should be the motor caravan makers that pick up the bills,I have never seen an American RV having a problem dumping,or a fuel tanker or the hunny wagons because they have properly designed  outlets on the vehicles
  • brue
    edited January 2018 #25
    Motorhomes vary so much due their layouts etc, they're never going to be the same just as caravans have always varied a bit. But poorly designed and positioned Motorhome Service Points on sites often cause problems due to being difficult to use or park up in. TDA mentioned Warwick, which is really awkward, often leaving waste water running all over the roadway, in icy conditions it's awful.
  • Qashqai66
    Qashqai66 Forum Participant Posts: 551 Participant
    edited January 2018 #26
    One of our favourite CL sites has a vast concrete apron which slopes towards the centre where there is a drainage grill.  I congratulated the owner on the design and he told me that the Club had insisted on it and given hm exact specifications for the task.  I find that puzzling as I have never seen a similar arrangement on any other CL.
  • Takethedogalong
    edited January 2018 #27
    I think some of the Club's inspectors are fond of giving "advice" to CL owners, although in this case it seems to be a positive step. Won't have been cheap though.
    edited January 2018 #28
    Sorry JVB66 that is complete nonsense. Next you will be telling me that the makers of Waste Masters, used by most caravanners,  should pay for the removal of all the brick lips previously used around waste water disposal points which have been replaced by the current level system? Many American RV's have a combined grey and black waste system so requires a large diameter dump point, for obvious reasons,  be that by hose or direct evacuation from under the vehicle.
    edited January 2018 #29
    That’s a good one, JV. You crease me up.laughing
    edited January 2018 #30
    You're almost right in your first paragraph, Nav, except one drain per site would suffice.
    Get your girlfriend to try lifting one of the manhole covers and you'll gain an insight into one of the issues.surprised
    edited January 2018 #31
    The removal of the brick surround has made the area a very unsafe place in cold weather as water goes every where,and all because "some"were "incapable" of useing the original design ,and RV owners seem to manage, but then they maybe have the right equipment on their vehicles,
