Truma Ultrastore Water Heater failure
Rosie Rabbit
Rosie Rabbit Forum Participant Posts: 85 Participant
I am currently on a CL site no electric. Been using gas to heat my water, all fine until this morning. The red failure light keeps coming on - tank is full, no airlock and gas works OK everywhere else.
Am in a panic as I can't take it in anywhere as I am full time now in caravan for next year.
Do people come out and repair? Anybody any ideas as to what might be wrong? I have a Abbey Freestyle 470 SE 2001.
  • Bakers2
    Bakers2 Forum Participant Trusted Posts: 8,657
    edited August 2017 #2
    Yes can get mobile repairers and engineers. Can help with problem sorry. Where are you? That way someone may be able to recommend a mobile person. Could try go ogling local to you repairers. Good luck.
  • Rosie Rabbit
    edited August 2017 #3
    Just north of Worthing, West Sussex. Thanks for getting back so quickly. Was thinking - should I drain it and refill it maybe something needs to be reset?
  • commeyras
    edited August 2017 #4
    Try S&G Caravan Services on 07842451805.  They are based in Lancing and are an 'Approved Mobile Workshop'.
  • Rosie Rabbit
    edited August 2017 #5
     Thanks for that, have just called and left a message on their mobile. BTW did the drain and refill and nothing - I could hear it do a few fast clicks and then a deeper sounding click which was the failure light coming on. Grrr! Cold showers and me do not mix!!
    KjellNN Club Member Posts: 8,992
    edited August 2017 #6
    Is your battery in good condition?  The battery is needed for the gas ignition, so if the voltage is too low the ignition may fail.
