A-frame mounted cycle carriers
Adelaide
Adelaide Forum Participant Posts: 10 Participant
We have a Thule bike carrier fitted onto the a-frame of our new Eriba Troll. There seem to be a number of different opinions about how to actually put the bikes onto the unit - the instructions aren't particularly clear. Also, must I take a pedal off one of the bikes every time I use it, in case it damages the caravan? Help!
  • eurortraveller
    edited July 2017 #2
    Adelaide, Is there really enough space and clearance to carry two bikes on the A frame of an Eriba?  Best  if you go on to one of the two specialised Eriba forums and ask the question there - - they have aficionados who will know the answer down to the last nut and bolt.. Enjoy your new caravan.
    DavidKlyne Club Member Posts: 14,797
    edited July 2017 #3
     Can't answer the question about your particular caravan but with regards the pedals I have, in the past purchased some foam pipe insulation and cut it into short lengths so that it just clips on the the ends of the pedal, this might prevent damage.
  • Tammygirl
    edited July 2017 #4
    Could you not change the peddles for folding ones, we have those on our folding bikes, much better than removing them.
    edited July 2017 #5
    I have seen people doing this and wonder what happens when the towcar and caravan are on full lock. It would need a very long A-frame for the rear corner of the tow vehicle not to come within a few inches of the front panel of the caravan.
    I just had a look at my own set-up and there is not enough space for even a child's bicycle, unless it was carried vertically. Have you actually measured this out on your own caravan?
  • Boff
    edited July 2017 #6
    Don't the handle bars stick out further than the peddles, or am I missing something?
    Eriba's don't have very long A frames but British vans have very short oneswink
  • Adelaide
    edited July 2017 #7
    Eribas, like most German caravans, have long a-frames. The bike rack was fitted professionally by the dealer, and we now have two full size adult bikes on board. We simply removed a pedal to ensure no damage to the caravan. Plenty of turning circle space too - the bikes don't even protrude either side of the caravan. Thank you for all your comments - off on Sunday to the Netherlands, so we'll see how we get on!
  • EuroTrotters
    EuroTrotters Forum Participant Posts: 17 Participant
    edited July 2023 #8
    I am looking at a Fiamma A frame 2 bike carrier for our Hymer caravan. The Hymer does have the longer A frame.
    But I am worried about not being able to open the front locker or use full lock !
  • Vulcan
    Vulcan Club Member Posts: 676
    edited July 2023 #9
    Remember also that two bikes mounted on the a frame will add a significant amount to nose weight.
  • Burgundy
    100 Comments Name Dropper
    edited July 2023 #10
    My thoughts exactly. + the weight of the carrier
  • EuroTrotters
    edited July 2023 #11
    thanks. doesn't look like it will suit my so roof of car or boot.
  • wh1nbrew
    wh1nbrew Club Member Posts: 141
    edited July 2023 #12
    I recently fitted a Thule one to a Bailey D4-2, and the rack tilts forwards, supposedly enough to open a front locker, though our Bailey doesn't have one.  I saw a Fiamma version fitted to a Fendt van a couple of weeks ago, so presumably this works OK.
    Now, a word of warning if you are using E-Bikes.  Both the Fiamma and Thule racks use fairly narrow rails for the bikes, which because we have 2.5 inch diameter tyres on our bikes are a bit on the narrow side.  Additionally, the rails are only just long enough for our particular bikes (130 cm rails, 125 cm wheelbase!), and the front one is split (both Thule and Fiamma).  Neither company make a suitable ramp to ease loading of heavy E-Bikes onto the rack.
    I am in the process of trying to fond suitable alternative rails - longer and wider.  So far, I have narrowed the choices down to the Thule 591 roof racks, and discard the fittings and bolt on the rails in place of the existing ones, but am unsure of the positioning of the rails in relation to the rest of the rack, i.e. will the load be even?  The alternative is the Fiamma rail - carrybike rail premium XL at 139 cm (Fiamma part number 98656M132) - but can only find these new, not on Gumtree or similar.
    As for a ramp, I have cobbled together something using aluminium sections from B&Q and an Atera folding ramp (part number 022 742).  This is still rather short but far better than having to lift the bikes on.  I have filled the gap in the from rail using right angle aluminium section, again, B&Q.
    If you don't have heavy E-bikes, then lifting on ordinary bikes is no problem - we have taken the normal (non E-Bikes) with us, and this is a doddle.
  • eribaMotters
    edited July 2023 #13
    I have recently collected a new Eriba Feeling and fitted a Thule Superb cycle carrier to the A frame.
    It is worth noting that Eriba have a long drawbar, as do many German caravans.
    Hymer/Eriba specify the Thule Superb, but it is also available as a Thule Superb Short and it's not clear which is the factory fit option. I looked at many vans on the Dutch Marktplaats website and it appears both have been fitted.
    The Short projects about 80mm less towards the hitch than the standard. It is also distinguishable by not having an extra row of holes for a third rail. The shorter model would be better for your nose weight, but it would be a lot tighter to get the bikes on.
    The tilt mechanism of the carrier does allow access to the front gas locker.
    The reversing lock is obviously effected by the projection of the bikes, but I did not find this an issue on my previous front mounted carrier on an Eriba. The only time it might be a concern is when doing tight reverse and then I usually have my lovely other half guiding me.
    The nose weight must be considered. After fitting my carrier I loaded both [non electric] bikes on and took nose weight readings with the van in it's typical load state. It soon became apparent that removing the front gas locker stored spare wheel into the car brought the nose weight down to the level I required. This is in the region of 60/65kg.
    Colin
  • mickysf
    edited July 2023 #14
    We discuss two issues, nose weight and restricted turning circle.
    Hasn’t our hobby always demanded thinking outside the ‘box’ and compromise. With the weight issue it’s a balancing act with redistribution, possibly to car, and maybe a rethink of some actual items we really need not take with us.
    I’m also reminded of those in our number who tow cars behind motorised caravans, they can’t reverse but with a little thought and modification of behaviours still manage to enjoy their tours. Caravans, even with aframe bikes, still can.
  • wh1nbrew
    edited July 2023 #15
    Aha.  It looks as though the Bailey has a very long A frame compared to (in this case) the Eriba.  You wouldn't be able to fit a continuous rail as a replacement as easily as I can.  I didn't notice this level of difference when I saw the Fendt - so A frame racks may still not be as usable for heavy E-bikes as I thought.
    Agree about rebalancing - we simply moved a small amount of kit from the front into the rear bathroom.
  • eribaMotters
    edited July 2023 #16
    The A frame length is 1.2m on the 6.07m Eriba. The cycle carrier is rated at 60kg. I met a Dutch couple last year with the same caravan and carrier. They had 2 electric bikes on it and found with the batteries removed they could get the correct nose weight without any problems.
    As has been mentioned above it's about modifying your approach and then most things are [safely] possible.
    Colin
  • OldDave
    OldDave Forum Participant Posts: 5 Participant
    edited July 2023 #17
    Our caravan is also of German origin but not an Eriba and yes, it also has the longer A Frame. The maker stressed this when we bought it as evidently the Germans advised it gives better stability when towing. I have to admit we have never experienced any snaking issues whatsoever at speeds i should maybe not mention. It aslo reduces the nose weight due to the extra distance from the van. We have also found it makes opening the car boot so much easier. It can take a bike frame but we have not chosen to do so. Opening the front caravan locker would be a bit more awkward from having one. As mentioned by others asking the Eriba Group would probably give the best answer to the OP's question
  • wh1nbrew
    edited August 2023 #18
    Update to earlier post.
    I replaced the original Thule rails with longer ones from Fiamma.  A bit expensive and a bit of a faff as I had to buy longer stainless bolts and use the 20 mm aluminium box section to raise the back rail as the Fiamma rails are somewhat wider than the originals and wouldn't fit squarely in the tubing.  Ah well. But one benefit is that the Atera (!!) ramp fits the end caps of the Fiamma rails, so is a much smoother transition.
    This still doesn't solve one of the original queries - it is still fiddly to get the first bike on the carrier due to close proximity to the stabilising loop, but a heck of a lot easier.  I think only a redesign, in the case of our bailey, making a single (lower) level frame from stainless with a quick release / fastening stabilising loop will work better - but I am seriously tempted to do so.
    And my current modification will probably not resolve the problem with the Eriba either.  So if anyone from Thule, Fiamma, Atera (?) or other suppliers of A frame bike racks is looking, a redesign suitable for heavy E-Bikes is called for.
