ATC Indicator LED
Options
JohnM20
JohnM20 Club Member Posts: 1,423
At some point in the last week the LED indicator on my 2 year old Al-Ko ATC unit has failed.  On inspection, it appears that there is a lot of corrosion on the connection between the cable and the actual LED which has caused a break. It looks as though water has got into the sheathing around the connector.
I have spoken to Al-Ko who have said that I must refer it to my supplying dealer as a warranty claim. This is OK except that they are now 120 miles from where I live which is a very long way to go just for a replacement plug in cable. (I also have issues with the dealer about the quality of their work). Al-Ko are not prepared to send me a new cable, which to me, and for what little they must cost, doesn't seem like good customer relations.
I have heard elsewhere that this is a known problem but has anyone else had experienced this fault and, if so, how did you rectify it?
Welcome!
  • ChrisRogers
    ChrisRogers Forum Participant Posts: 435 Participant
    edited April 2017 #2
    Mine was sorted at it's first service under warranty.
  • S2SAP
    S2SAP Forum Participant Posts: 75 Participant
    edited April 2017 #3
    Mine has also failed two weeks ago on a caravan that is not 1 year old. I contacted ALKO as previous posts on here indicated that they would send a new one directly but they told me the part had to be replaced by the dealer directly. They also said they were out of stock and wouldnt be back in stock for several weeks!! My van is due its first service next month so I will arrange it then under warranty but it appears that ALKO have had a change in attitude to supplying the parts directly.
    If you really dont want to do the round trip to the dealer the part is available on ebay for £29.99.
    edited April 2017 #4
    And £30 for a tu'penny ha'penny led on the end of a cable is just profiteering. ....
  • S2SAP
    edited April 2017 #5
    MollysMummy - £30 on ebay - £65 direct from ALKO !!!!!!!undecided
    edited April 2017 #6
    Where do you get your c/van serviced, they should be able to do it under warranty
    edited April 2017 #7
    That's even worse. But no different from car dealers
  • JohnM20
    edited April 2017 #8
    Because the ATC unit was fitted by the dealer and not actually by Lunar, the warranty will not cover the unit even though only two years old. Al-Ko's policy is 1 year if dealer fitted but the full length of the caravan warranty if fitted by the actual manufacturer.
    I reluctantly spoke to my supplying dealer who said they could supply me with the cable at just over £40.00!!!. I told them where they could put their cable as they are available as said by others at less than £30.00 online. However, I contacted another main dealer 10 miles away from home and got one off the shelf for £25.00, (still a rip-off for a metre of twinflex cable, a 50 pence LED and a 10 pence connector as MM has already said).
    An interesting comment that my supplying dealer made was that "this (corrosion between the cable and the LED),  is a known fault" and was confirmed by the dealer that I actually got the cable from. His recommendation was to put silicone sealant around the vulnerable area to keep moisture out. Fitting took about 15 minutes.
    edited April 2017 #9
    And the reason that I always use a hitch cover when not towing
    edited April 2017 #10
    I'm sure water still will find its way up from the road side to the underside of the led on the A Frame ..... innocent
  • DougS
    DougS Forum Participant Posts: 327 Participant
    edited April 2017 #11
    I don't know if this would work but if ours goes I'll be trying:
    http://www.maplin.co.uk/p/5mm-bi-colour-led-qy83e
    Unsure if it's 5mm or 3mm but they do both.
    As said, clear silicone and a standard holder, perhaps:
    http://www.maplin.co.uk/p/5mm-recessed-chrome-bezel-led-holder-n90ax
    may well be a cheap fix as the quoted prices are eye watering to say the least.
    Can any electronics whizz comment?
    edited April 2017 #12
     I'm no whizz kid,  electronic or other wise, but a quid on the 2nd option would be worth a try (I think I might even already have something like utnin my garage )
  • stephen p
    stephen p Forum Participant Posts: 194 Participant
    edited April 2017 #13
     It will be the 5mm version and you wont need the bezzle, just pull the old LED out of the existing bezzle.
    The wiring will need sleeving after soldering, Heat shrink sleeving would be best for this. Slide a length of sleeving over the joints and heat with a hot air gun or the edge of the soldering iron.
    http://www.maplin.co.uk/p/15mm-heat-shrinkable-sleeving-1m-bf86t
    If you are not used to soldering small wires get a spare LED, too hot for too long & you will damage it. Polarity is not an issue if you get it wrong it will be red when it should be green, try it before you sleeve the wires or stuff it back in the bezzle. Seal the bezzle with silicon or araldite. this will make a better job than the original and it will not fail again.
    This makes the prices mentioned in this post look like the rip off they are.
  • xtrailman
    edited April 2017 #14
    Yes its just a two leg inverse parallel led.
    When current flows in one direction it lights up red, in the opposite green.
    Two things, check that the current is limited to 25ma as per spec, and that the two wires are connected the correct way, if not reverse the wires.
    If you do need to reduce the current use a suitable resistor. It might be worthwhile looking at the old led to see if its got a resistor inside.
  • Bandit1952
    Bandit1952 Forum Participant Posts: 1
    edited March 2019 #15
    You can obtain the LED from ebay,the correct one for the job...You will need a soldering iron or very small connector to terminate LED to twin core cable..I also suggest a sharp blade,I used a stanley knife to cut along the cable to expose the connecting points..Also molegrips to clamp to the cable to stop it falling through hole in the hitch cover...After terminating led connect caravan to car and see if the led is green or flashing green,if not reverse connection and use insulation tape to cover the connection.....Repair complete for £6.75 which is still a rip off for the price of an led but still better than the rip off price of £40 for the complete unit which should really be under a tenner in my opinion....
  • xtrailman
    edited March 2019 #16
    Same here, in fact I relocated mine as the cover didn't actually cover it where Swift fit it, Bailey one was ok.
    I also apply silicon grease or contralube to the joints, so far I haven't had one fail, Bailey one was 6 years old when it went, Swift is 2 years old next May.
    But should it fail I'll make my own using either 2 Leds connected inverse parallel or by a Bipolar one.  The problem is getting one large enough so it would be smaller, and you may need a dropper resister to keep the current with in limits, having not taken the Alko apart I can't say if there is one.
    then again I don't really need the Led as I have ATC status on the swift App.
  • Rufs
    Rufs Club Member Posts: 4,098
    edited March 2019 #17
    statements of this sort make me smile, i read this post with interest, bearing in mind i am not a mechanical person in any shape or form, but i do have a 2008 Coachman fitted with ATC and it is still working perfectly with all original fittings, all i do is squirt some WD40 in the general area now and again, and like ET always use a hitch cover.
  • xtrailman
    edited March 2019 #18
    WD40 is only a water dispersal spray that does nothing to prevent corrosion. Buy the cover does.
    edited March 2019 #19
    edited March 2019 #20
    Dispersing the water will always help prevent corrosion 😉
  • Rufs
    edited March 2019 #21
    did have a look this morning, look dont touch, leave that for them that knows, WD40 multi use seems to be doing the job, no corrosion, just gave another squirt for good measure
Welcome!
