Help please? Quest, 3 way cool box.
Options
artyboo
artyboo Forum Participant Posts: 457 Participant
edited April 2017 in Parts & Accessories #1
i wonder if anyone has a bit of knowledge around a 'Quest' three way cool box. We bought this from a well known auction site last year, we used it on our sojourn in Sept, with electricity and all was fine.
I now want to run this off gas when I need however, all gas bits are missing (apart from the brass screw inside). I have attached some photos. I am guessing it is all quite simple (Duh) but can anyone suggest which fittings I need. I have been on the Quest Website but they were no use at all.
is this cool box gas salvageable? As ever, advice greatly appreciated
Welcome!
  • Vicmallows
    edited April 2017 #2
    Unfortunately no photos attached.
    This sounds like a standard 3-way top-loading fridge sold under numerous brand names.  I have one, and it works on 240v/12v/gas.
    I have no idea what you mean when you say "all gas bits are missing". Was this purchased new, or was it something sold 'for spares or repair' on the well known auction site?
    If you can clarify what you need to know I may be able to help.
  • artyboo
    edited April 2017 #3
    Hello,
    thank you for your response. Yes, it is the standard 3 way fridge but the gas pipe and fitting are missing.
    i have tried again to attach a photo but I Can't.
    there is a brass 'male' fitting ready to receive a pipe but I am not sure what to buy.
  • Boff
    edited April 2017 #4
    I suspect all you need is a length of pipe and a regulator.   To light turn gas control to max press down and press the spark button a few times.
  • Vicmallows
    edited April 2017 #5
    The fitting you need is almost certainly a 1/4" LH thread female -to- Fullham nozzle adapter.  One of these should have come with the fridge.  The same screw fitting is also used by Camping Gaz in some European countries, and you could use one of these, cutting off one end, ....but it would be an expensive solution!
    You then just need a standard 28/30mb regulator to suit your gas bottle.
    If I can find a source for the part you need I'll get back.
  • Boff
    edited April 2017 #6
    I assume that brass male fitting, is a Fulham nozzle. Therefore I think what is need is a length of 8 mm gas pipes then either a regulator into a bottle or a quick fitting if conecting onto a caravan BBQ point as I do with my fridge.
    PS our fridge bought new came with nozzle as described but no pipe or other fittings.
  • Vicmallows
    edited April 2017 #7
    I think the fitting you need is THIS
  • artyboo
    edited April 2017 #8
    Thanks all.
    I have ordered fitting, pipe & regulator. Let's see if it works x
  • artyboo
    edited April 2017 #9
    Hoorah,
    fittings and pipes work.
    thanks for all your suggestions; really appreciated
Welcome!
