Problems with gas oven.
blone
blone Forum Participant Posts: 3 Participant
Wonder if anyone else has had problems with gas oven We own a Bailey Pursuit and for two years the problem persists. The oven ignites but flame won't stay on. Dealer has " repaired" it several times but doesn't seem to come up with a valid explanation.Help!
  • Bakers2
    Bakers2 Forum Participant Trusted Posts: 8,622
    edited April 2017 #2
    Silly question coming up 😯. Is the lid completely upright? We've had this and it wasn't completely straight so safety cut-out cut in. I find I need to hold the button in for quite some time after ignition otherwise the flame dies. Once it's got a bit warm it's fine.
    Tinwheeler Forum Participant Trusted Posts: 24,161
    edited April 2017 #3
    The usual cause for the oven failing to stay lit is that the thermocouple which keeps the flame alight (the little black spike by the burner) can be missed by the pilot flame and therefore does not get hot enough to work. Alternatively, the thermocouple or valve maybe faulty. Very few caravan engineers seem to be aware of this.
    It is easy to check if the thermocouple is working correctly. When holding the button in to light the oven, the pilot flame should light and the thermocouple should glow a dark red colour. If it doesn't, then refer to my first paragraph.
    Ensure that the glass hob top is fully open before trying to light the oven if your oven is of the type that requires this. Not all are.
    edited April 2017 #4
  • blone
    edited April 2017 #5
    Thank you for suggestions. Dealer is going to fit a new valve. I am not convinced! Watch this space!
  • Peter and Carisa
    Peter and Carisa Forum Participant Posts: 2 Participant
    edited May 2017 #6
    We have a Bailey, and had same problem, oven wouldn't stay lit from brand new. We took it back to dealer who 'fixed it', but next trip, exactly same. We got authorisation to use a local caravan engineer who fitted the thermocouple properly !! It has been fine since
  • Oscarlinus
    Oscarlinus Forum Participant Posts: 1 Participant
    edited August 2021 #7
    We bought a Frankia fitted with a Dometic oven. The flame goes out after a while. Initially we thought it was linked to when using the external bbq and oven at the same time. Also that maybe it happens when we open/shut the door (at the side of the oven). Today has confirmed that it happens on its own. The flame appears to be lifting off the jets at the ignition end, just before it goes out.
    Instruction above oven states open roof vents ( done that), staycation currently prevents all windows being open .....
    Is it the thermostat?
    edited August 2021 #8
  • ScreenNameD4EFB96F17
    ScreenNameD4EFB96F17 Forum Participant Posts: 1 Participant
    edited September 2023 #9
    Another possible cause is that the Thetford Caprice Mk III oven in our Bailey Unicorn frequently cuts out due to a build up of carbon on the thermocouple. For some reason it seems to be vary susceptible to this. I find that if I give it a quick clean every couple of uses and it works fine. Just get rid of the accumulated carbon which stops the thermocouple registering a temp and therefore cutting the supply off. Obviously do this when the oven is cold before use. Hope that helps.
