Fresh Water Container for Fully Serviced Pitch
Due to health reasons, I now use Fully Serviced pitches at every opportunity. I connect up the fresh water hose to the side of a 40 litre aquaroll using a ballcock to control the flow. However, when leaving the site, I pour away at least 20 litres, unless, I have remembered to switch off the supply earlier. So I have been looking for a plastic container (jerrycan) about 20 litres, with two caps the same size as the aquaroll. One on top and one in the side. On Ebay the only ones I can see include the ballcock and range in cost from £30 - £50. Having already got the ballcock I don't want to pay that much. Can anyone kindly point me in the direction to buy just the container?
Sorry can't help with the container. However, if you go down the route of using a 20 litre container, what reserve does the ball cock give. At least 20 litres means the pump does not suck in air when in continuous use for a shower. Would that be the case with a smaller reserve?
0 -
I guess Steve the ballcock would maintain about 10 litres in the container. Would think this continuous supply would be enough for showers. Currently when I use the aqua roll it never goes below the ballcock. Thanks for responding.
