Bailey Orion 430-4 - Replacing Amber Side LED unit
Options
Hello all
Perhaps someone knows how to replace the Amber oblong l.e.d. unit on the lower side rail on an Orion 430-4. The light is held on by 2 screws and when removed there are 2 leads terminated in spade fixings. Of course when I pulled the lead as carefully as I could, they parted company with the supply leads which are where, in the lower rail or inside the caravan. If in the rail, how does that detach from the caravan, and in the caravan where is the supply lead hidden behind (this light is the one located near water heater / side of fridge on the off-side?
Hopefully someone has an answer please. (I have a replacement)
thank you
Richard
