Awning carpet, which way?
G Cherokee
G Cherokee Forum Participant Posts: 402 Participant
Hi people,
When erecting your awnings, how do you begin?
Roll our the awning carpet then put the awning up on top?
Or inside?
Where does the mud skirt go?
How do you fix it down so it doesn't move around?
Thanks in advance.
  • Whittakerr
    edited January 2017 #2
    I roll the carpet out fist and then unroll the awning on the carpet to help keep it clean and stop it getting damaged on any sharp stones that may be there.
    As for the mud skirt, mine goes on the inside and I then put the carpet on top of it to stop any draughts. I don’t normally need to peg the mud skirt down as the weight of the carpet holds it in place, but I do carry some ground sheet pegs if it’s particularly windy.
  • ocsid
    edited January 2017 #3
    Much the same, I put ours down sufficiently unfolded and biased so it is positioned below the end of the awning rail into which the awning is to be fed. I am a separate parts awning erector, roof sides etc, not a one piece man.
    All focused on keeping the awning parts clean, protected and not picking up grass cuttings etc.
    Then it either gets deployed and moved where needed if indeed we need it or if the grass is pleasant then it is refolded and put back in the car. Alternatively still well folded it gets left by the step to stand on and leave shoes on, when coming and going.
    We don't particularly like ground sheets and certainly not the damage they can do if left down too long so tend only to use them on scruffy pitches, not where the grass is pleasant.
  • Hakinbush
    Hakinbush Forum Participant Posts: 286 Participant
    edited January 2017 #4
    I normaly take the awning down the day before (weather permitting) take the pegs out and hook the bottom of the awning up onto the frame wipe mud wall clean, only gets mucky on grass pitch's where carpet is frowned upon...naughty naughty....
  • eurortraveller
    edited January 2017 #5
    Try life without an awning, Cherokee, just like motorhomers do, and because awnings cause all the extra work that other people have just described. Sit outside if it's sunny , sit inside if it's cold. Just like motorhomers do.
  • G Cherokee
    edited January 2017 #6
    When there is Jules and myself, we dont bother with the awning, especially if the weather is fine, but on wet days it gives somewhere to hang wet coats and dry off out loony cocker spaniel.
    My question relates to keeping the damp off the carpet when the heavens open,
    Mud skirts on the outside leading away from the awning.?
    Mud skirts inside, under the carpet.?
    Mud skirts inside, on top of the carpet?
    We dont use a ground sheet, just the woven type carpet.
    KjellNN Club Member Posts: 9,026
    edited January 2017 #7
    Which way do your mud flaps usually go, only some awnings can have them either in or out?
    If they have to be in, then tuck them under the carpet.
    If you can have either then in and under means fewer draughts, out means more ventilation and less condensation.
  • ocsid
    edited January 2017 #8
    On the point of mud flaps inside or outside I have never had an awning giving a choice; all have it  sown onto the mudwall with the pegs being fixed outside, so mudflap falls "inside" the pegs.
    If enough length, [that depends on ground profile] I put the awning's mudflap under any ground covering. If there is not enough I put a slight bellows in it and peg directly under the mudwall.
  • G Cherokee
    edited January 2017 #9
    Thats the way I`ve being doing it......... Yay!
    But if I want to secure the carpet to stop it sliding about, (which it does). doesn`t that mean I`m pegging thru the mud skirt??
    Or is there a sneaky fix I`m unaware of ???
    Cheers guys
