Amp meter and water pump not working on Bailey Pag
Options
s13wye1965
s13wye1965 Forum Participant Posts: 1 Participant
Could anybody help me please my amp meter and water pump are not working on my Bailey Pageant series 5.I was wondering if it could bo the battery charger please help thank you
  • Wildwood
    edited August 2016 #2
    I assume the other electrical items are working so it is these two that are a problem.
    The caravan should have a battery charger fitted which works when hooked up to the mains. If you are not getting a reading when hooked up or off a working battery on the meter it sounds like the meter has failed but check
    the fuse first.
    If the pump is not working check the fuse first but it could also be the pressure switch.  Not sure what pump you have, drop in ones usually have this near the water inlet in the bed locker, it is a rotating switch that you turn to adjust. On board ones
    usually have it on the pump itself.
    From my experience pumps do fail regularly but you need to do the other checks first.
    It may be others can come up with other ideas though.
Welcome!
