Cold water system
G Cherokee
G Cherokee Forum Participant Posts: 402 Participant
Hi again,
Well we've been here a day and really struggling with water system.
With a bit of luck we managed to fill the onboard tank from the aquaroll, and managed to have water all day. But now the tank is empty which I've refilled but the water is not coming thru.
We have,
An on board tank
Aquaroll
Switch panel above door with electrics and battery/water level gauge. Tank or aquaroll switch.
And a switch labelled " Tank Fill"
Valve under the seat to tank
And a yellow valve switch which I'm guessing is the hot water tank drain.
Can someone please tell me how this all works!!
The guy did explain when we collected van but there was that much to take in its been forgot
Cheers
Dave
«1
    KjellNN Club Member Posts: 8,972
    edited August 2016 #2
    have you not got the handbook?
    Which van do you have?
    Handbooks are available online.
  • G Cherokee
    edited August 2016 #3
    Its a Swift Conqueror 580
    The handbook doesnt tell you how to get water to the taps!!
    Tinwheeler Forum Participant Trusted Posts: 24,232
    edited August 2016 #4
    So, if I've got this right, you've filled the onboard tank from the external Aquaroll but the water refuses to leave your tank and come out of the taps?
    Is there a switch on your panel for pump/taps? There usually is to allow you to turn the pump off when you go out to avoid returning to a flooded van should a leak develop.
  • G Cherokee
    edited August 2016 #5
    Yeah, I've switched the valve off on the feed from the aquaroll. Switched off the tank fill switch, switched to "tank" on the leccy panel but no water
    edited August 2016 #6
    It's near impossible to diagnose without seeing the set up, GC. My only other suggestions are to appeal for help to someone with a similar van on site, or the warden - although he probably won't be happy at this hour.
    Alternatively, you might stand a better chance of finding someone on here who knows if you post in the Caravan section.
    Sorry, I can't help further.
  • G Cherokee
    edited August 2016 #7
    Thanks Tin appreciate the input,
    Guess we'll be headin home stinking Yell
    edited August 2016 #8
    Wish I had the magic answer, GC.
    I'd throw myself on the mercy of another vanner or warden in your position. If they shy away you'll know you're stinking.Surprised
  • ABM
    edited August 2016 #9
    Do  you  have  a  button  on  your  control  panel  marked "Levels"   GC  ??
    If  you  have = press  it,  it  should  shew  if  your  fresh tank  is  holding  water  and  the  voltage  of  your  Habitation  Battery..
      then  do you  have  button  marked  "water  pump"  or  just  "pump". If  so  Press it  &  you  should  hear  the  pump  going !  If  it  does  not  run, it  sounds  like  an  electric  problem.  If  it  runs  but  still  no  water  ensure  you  have  a
    Hot  tap  open,  then  a  Cold  tap  ==  if  no  water  comes  close  both  &  turn  off  pump  'cos  it  may  be  running  dry  ==  some  pumps  can  do  themselves  damage  if  running  dry.
    Sadly  here  endeth  any  help  I  may  or  may  not  have  been  able  to  offer
    Sad
    edited August 2016 #10
    You need to say the model year, as there  have been several different water systems lately.
    We have a Swift, but MY 2008.
    edited August 2016 #11
    Can you pump water through your taps from the aquaroll? That will at least establish that the pump is working. It could just be an airlock.
  • G Cherokee
    edited August 2016 #12
    Its a swift conqueror 580 sal 2004
    All water vessels full
    Both pumps working
    There is a switch to change from onboard tank to aquaroll.
    A tank fill switch
    A valve by the on board tank
    We had it all working off the onboard until i needed to refill it
  • KENNYG
    KENNYG Forum Participant Posts: 215 Participant
    edited August 2016 #13
    I have a 2008 ace I have a very similar problem on accasions pump is working but no water usually an airlock. Try unplugging the fillter pipe from the van take fillter out of aquarole then put fillter back into aquarole giggle it about then plug it into
    the connecter on the side of van turn on hot water tap this usually works.
  • KENNYG
    edited August 2016 #14
    Embarassed oops I think that should be jiggle.
    edited August 2016 #15
    Did you remove the external pump after filling ?
    Did you return the valve under the seat to the using position rather than the fill position?
    edited August 2016 #16
    It's not quite the same, KG. The OP has pumped water from his Aquaroll into the onboard tank but cannot then pump it from the tank to get it to come out of the taps.
    edited August 2016 #17
    It would seem logical that the external pump, when selected,  could supply the taps direct from the Aquaroll, and that the internal pump, when selected,  could supply water from the onboard tank, but there is the added complication of the tank fill switch.
    Instructions for filling say to plug in the external pump, select external pump on control panel and turn it on using another switch, presumably the tank fill switch.  one also needs to have a valve on the pipework in the correct position to allow water
    to flow into the tank.
    Once the tank is full, according to the handbook,  the external pump should be deselected, the tank fill switch turned off, the external pump umplugged, and presumably the pipe valve returned to its using position, though this is not stated.
    It then refers to selecting internal pump and opening a tap.
    It makes no mention of using direct from the Aquaroll at this point, though it says earlier that this is possible.
    edited August 2016 #18
    Seems very complicated compared to our 2008 system which uses only one, internal pump to fill tank and use from either in or out by means of 2 valves on the pipework which can be combined in 3 different positions.
    edited August 2016 #19
    If GC's system has only one valve with 2 positions, one position must allow filling of tank and the other position allow water to flow direct to the taps from outside.
    The question is which is the correct position for using from the tank, possibly the filling position?  In which case the valve should not be altered when moving between "filling tank" and "using from tank".
    As you said TW, very tricky to advise without seeing exactly what is there!
    edited August 2016 #20
    I think you've summed it up, Kjell, as far as it's possible to without being on hand.
    edited August 2016 #21
    Mmm, I've now had a look at the water layout diagram in a 2004 handbook, seems to be only one valve, so a fill/use tank position, and a use Aquaroll position.
    The wiring diagram in the 2004 technical handbook does not shed much light on how the various switches interface, so I just wonder if having the external pump plugged in somehow interferes with getting water to the taps, as it specifically says to unplug it after filling.
    With a switch that selects only one pump at a time, I cannot see how having the external pump in place should affect anything.
    edited August 2016 #22
    GC.....do you have a pressurised system or a microswitch system?
    If you have wires going up to the taps it is microswitch.
  • G Cherokee
    edited August 2016 #23
    Hi again K,
    Yes it is a pressurized system with micro switches on the taps.
    Having read your in depth posts I can only confirm that you are on the right track.
    I'm obviously missing something to get the water from supply to taps, like the newbie numpty I apparently am!!
    edited August 2016 #24
    Yes it is a pressurized system with micro switches on the taps. ....
    They are two different systems. Pressurised systems have a pressure switch that detects a drop in pressure & runs the pump up until the system is back to pressure ie you open a tap, pressure switch sees drop in pressure, runs pumps, you get water out of
    tap, you close tap and the pump can now pressurise the system which the pressure switch sees & stops the pumps. Microswitched system works by switching the pump on via any of the microswitchs on each of the taps.
    edited August 2016 #25
    Hmm.
    Have you unplugged the external pump?  If not, do that now.
    Is your internal pump in the onboard tank, or separate?
    Which way have  you got the valve on the pipework set?
    When you open a tap, which pump runs?
  • G Cherokee
    edited August 2016 #26
    Write your comments here...
    The micro switches only kick in when it senses water pressure, so Im led to believe
    edited August 2016 #27
    Oh dear, I'm afraid you have been mis-informed!
    Not that that has any bearing on your present situation.
  • G Cherokee
    edited August 2016 #28
    Hmm.
    The onboard tank has its own pump,
    The valve is in the off position, as the tank is full and dont require feed from that pipe, (which goes to the Whale pump connection).
    We're back home now, later I shall fill the vessels up with water and try to fathom (ahem! Wink
    It all out without any pressure (ahem!) off my dearest better half.
    edited August 2016 #29
    Can you, later, look at your handbook and confirm whether it shows (on around page 25) a diagram of a typical water layout?
    If so, does it show there being only one pipe to/from the onboard tank?
    Is that in fact what you have in the van?
    If so, if you close the valve on that pipe, you cannot get any water to the taps from that tank.
    The valve should only be closed if you wish to use direct from the Aquaroll.
    Regarding the internal pump, what I was asking is whether it is actually IN the tank, or somewhere on the visible pipework.  I would expect it to be in the tank if your pipework is as shown in the handbook.
    Just trying to build up an accurate picture of exactly what you have.
    The handbook I have seen is not particularly informative IMO.
    Did you unplug the external pump when you had finished filling the onboard tank, as per the handbook instructions?
    Not doing so may have some (not immediately obvious) affect on getting/not getting water to the taps.
    BTW....you could do worse than join up on SwiftTalk, quite a few helpful owners and Swift people on there.
  • G Cherokee
    edited August 2016 #30
    K, your a star, I'll go see Swift talk now,
    I shall report back later in the week when I have time to go thru the system again.
    Cheers for your input
    Dave
    edited August 2016 #31
    No they don't ..... it works as described above Wink
