Leaky gas connecting valve
black caviar
black caviar Forum Participant Posts: 242 Participant
edited August 2016 in Caravan & Motorhome Chat #1
hello my fridge in caravan has defrosted , whilst on electric hookup , so as it wouldnt work on electric weve uncoupled and tried to get it to use gas only to discover that the gas bottle is empty and when weve connected to new bottle gas is leaking out
of connection (i thought we shouldnt have used all that amount if gas just fir two uses of oven!) have also connected to mini gas bottle and that leaks too! is this a common problem can gas connectors suddenly just leak ? its literaly blowing out? cheers mrs
bc:(
    edited August 2016 #2
    Have you checked out why it's not working on 240v? Perhaps it's something simple like a fuse.
    edited August 2016 #3
    What sort of gas. I use propane with a metal to metal seal. If I recall butane connector has a rubber seal inside the attachment nut.
    edited August 2016 #4
    edited August 2016 #5
    If gas leaking in front locker there should be no electric present - hopefully
    edited August 2016 #6
    edited August 2016 #7
    If gas gushes out as said then it isn't going to be used.
    As I said earlier if it is butane with the rubber washer/seal this could need replacing.
    'Check the black sealing washer on the regulator for damage before connecting—replace it if it’s faulty'
    https://www.calor.co.uk/butane-regulator-guide
  • black caviar
    edited August 2016 #8
    thankyooo for prompt replies have gone back into locker ,and looked at gas bottles ,and found that empty bottle had a rubber washer in connecting hole and other two full bottles hadnt ,came to conckusion that rubber washer actually belongs to regulator lead
    .....doh! we had been connecting rubberless beass to rubberless brass .... no wonder gas was blowin out ! have solced the mystery abd learnt something ! fridge is working on 240 again but then keeps switchin iff and red light comes on ,so only that to sort
    out at moment, will moniter it today,was out all day yesterday when it switched off ,so will see wot it doess ,it keeps clikking as if trying to change to gas (hence the discovery of empty bottle)and ensuing potential d.i.v.o.r.c.e , cos its not what you need
    ar 6am is it thanks for replies mrs bc:))
    edited August 2016 #9
    Make sure you buy a new washer as the chances are that one is shot. When I used butane I always kept a spare as they don't always last for ever.
  • Pippah45
    edited August 2016 #10
    My fridge is very unreliable on gas unless the caravan is absolutely level - but yours should work on 240 ok - you need an expert I feel.  Good Luck.
  • DORMAN12Q
    DORMAN12Q Forum Participant Posts: 90 Participant
    edited August 2016 #11
    Have you tried mixing a little washing up liquid with water to make a frothy mixture and squirting it on the joints?
    If it blows bubbles when the gas is on at the bottle the you have a leak.
    It is a simple test you can do your self.
  • jennyc
    edited August 2016 #12
    Write your comments here...
    You can buy propane pigtails with rubber to metal too - seems an obvious choice to me.
  • jennyc
    edited August 2016 #13
    We managed to do the same with one of our pigtails - never again
    edited August 2016 #14
    Never come across rubber to metal on propane .... only with butane
    edited August 2016 #15
    edited August 2016 #16
    Certainly as I have seen BB
  • Vicmallows
    edited August 2016 #17
    Many propane POL connectors now have a rubber nose 'cone' on the male end. This is replaceable just like the Calor butane washers, and readily available.
    edited August 2016 #18
    edited August 2016 #19
    Not seen those
  • black caviar
    edited August 2016 #20
    Hello again my gas bottles are orange which is propane and my adapter hose end is a "male" shape with a black convex rubber washer on the end ( but the rubber washer was left unwittingley in the empty gas bottle)hence we were trying to connect new gas bottle
    minus rubber washer...... Big mistake!
    Sorted now tho thanks
    edited August 2016 #21
    Apart from the gas bottle locker light!
    edited August 2016 #22
    Never seen a light in a gas locker. Is that something new?
  • jennyc
    edited August 2016 #23
    Well we use Calorlite bottles with stainless steel pigtails which have domed rubber seals where they go into the bottle. They also have large plastic wheels to tighten them on so we don't need spammers. Have a proper look on the web and you'll find them
    in different lengths.
