High Level Brake Light
NigelCowley
NigelCowley Forum Participant Posts: 1 Participant
edited February 2016 in Caravans #1
I have a Swift Challenger with a high level brake light; a few of the LEDs have failed.  Does anyone know of a legal requirement to have a high level brake light working?  MoT advice only mentions the normal brake lights each side on a trailer or caravan
and high level ones on the towing vehicle.
  • volvoman9
    volvoman9 Forum Participant Posts: 1,053 Participant
    edited February 2016 #2
    To be honest i cant see it being a legal requirement on a caravan but i dont know for sure..I have the same problem on our Coachman and i have tried too get a replacement but no luck so far.
    peter.
  • Nuggy
    Nuggy Club Member Posts: 521
    edited February 2016 #3
    One of my LED's stopped working, I gave it a thump and it's been working ever since.  Happy
  • huskydog
    edited February 2016 #4
    Maybe if a light is fitted it should work ,bit if theres no clear requirement ,it's a tricky one
    Have you looked in to the cost of a new one ??
    What would the insurance implication be if someone ran in to the back of you ???
  • Trini
    Trini Club Member Posts: 434
    edited February 2016 #5
    I understand if there is a light fitted it should be working and now as there is a high level brake light fitted to recent vehicles this would be required to work.
  • Wildwood
    edited February 2016 #6
    If your indurer mentions it then you can always say it was working when you set off.
    More to the point it is not the vehicle behind you that is the problem ad normally they watch the regular brake lights. The high level ones are so the one behind the one behind you can see you brake and they would hit the car behind you.
  • Nuggy
    edited March 2016 #7
    Write your comments here...The lawers could have a field day with this one. How many LED's need to be 'not' working before the light is considered defective? I would imagin it would be for a court to decide and a different set of magistrates coulld have
    a different opinion.
    edited March 2016 #8
    I understand if there is a light fitted it should be working and  ..
    Previous cars' front fog lights have never been checked at MOT time ..... so the tester has no idea if they worked or not.
  • bigherb
    bigherb Forum Participant Posts: 65 Participant
    edited March 2016 #9
     How many LED's need to be 'not' working before the light is considered defective? I would imagin it would be for a court to decide and a different set of magistrates coulld have a different opinion.
    Minimum of 50% of the LED's or incandescent bulbs must be working.
    edited March 2016 #10
    No requirement on a trailer as there is no MOT equivalent for them unless we stay in EU.
  • BigAlK
    BigAlK Forum Participant Posts: 3 Participant
    edited March 2016 #11
    The point of the extra brake lights (they don't have to be high level) is that following drivers might not notice the difference between the normal rear lights and the brake lights, using twin element bulbs, as fitted to the majority of cars.
    Although there is a marked difference in output between 5 and 21 watt bulbs, if the lights are perhaps dirty, and the following driver should be distracted at the moment that the brakes are applied the extra brake light is a useful means of alerting them.
    Stupidly our local ambulances high level / extra brake lights are twin element bulbs defeating the object!!
  • ClubMember1333A783BB
    ClubMember1333A783BB Forum Participant Posts: 41 Participant
    edited March 2016 #12
    Exactly and it's why rear fog lights can be so dangerous ....... the bright fog lights are very distracting and disguise the break lights! Has always suprised me that a different colour of light could not be used as fog lights?
    edited March 2016 #13
    Which is Mercedes' reason for fitting just one rear fog light (offside or middle) .... I disagree but ....
    What colour do you suggest? Blue? .... green? .... there's not much left after you disregard red, yellow & white Wink
    PS ..... it's a brake light ..... Innocent
  • Lyke Wake Man
    edited April 2016 #14
    I think it will be the same as a car, if it is fitted it must be working
  • Chris Ardis
    Chris Ardis Forum Participant Posts: 55 Participant
    edited April 2016 #15
    Bigherb's reply is the correct one. In a light with multiple bulbs or LED's there must be at least 50% in working order.
