Front corner reinforcement/replacement
Options
Monkey Bus
Monkey Bus Forum Participant Posts: 1 Participant
edited May 2013 in Caravans #1
Hi
After a year of ownership of my Lunar Lexon CD caravan I have just discovered (by accident) that the floor on the f/n/s corner has been damaged.  Nothing has happened during my ownership and it's not that obvious unless you are actually inspecting that area.
 I can only think that someone has dropped the caravan on to the stabiliser causing it to damage the plywood floor, or has used it to jack up the caravan.  Eather way, the corner of the floor needs supporting, or replacing so that the stabiliser can do what
it needs to when extended.
I've read somewhere that you can cut part of the ply floor out and replace it so long as you find the joist.
Has anyone come across this problem, or can anyone offer advice on how best to sort this problem?
I'm in West Sussex (Haywards Heath) and would appreciate any advice or guidance.  I can supply pictures if needed.
Regards
Phil (07748 611251)
