Battery or van problem?
SANDS
SANDS Forum Participant Posts: 22 Participant
edited August 2015 in Caravans #1
Hello can anyone advise me please. My battery is loosing its chrage very quickly when I have the master switch on in my unicorn seville mark 1. I don't know if the battery has failed it is nearly 4 years old or if there is a problem with the van. we were
away last weekend and could use everything during the day when the solar panel kept the battery charged but after dark it went flat very quickly. Yesterday I hooked the van up to our mains electric at home for 4 hours and after that the reading on the contril
panel was 12.75. I left the masterswitch off and disconnected the mains. after another 4 hours the reading had dropped to 12.25. i left the master switch off overnight and this morning the reading was still 12.25. I then left the master switch on but with
everything else turned off after just 40 mins the reading had dropped to 10.75. Not sure if I need a new battery or if there is some other fault, any help would be much appreciated.
Welcome!
