Convoluted grey water waste hose
My Swift Sundance has a 1m length of convoluted hose for the emptying of the grey water tank. The hose terminates in a plastic tap which is clipped up under the MH when not required. Guess what! when travelling this weekend the hose was dangling and the
hose has split.
I can get hold of replacement pipe easily enough but does anybody know how the hose is fixed at the tank end as it is all tucked away and covered in lagging
Option B. Has anybody found a better solution? Maybe a fixed tap to which a length of waste hose can be attached to when required?
Thanks all, Kevin
Normally with a jubilee clip.
I actually extended mine but didn't touch the jubilee connection as it was very rusty and didn't want to damage the tank!
I use a fixed hook/clip to hold the pipe plus a very small bungee cord as insurance!
0 -
As said ,cheap original hoses do tend to be a problem.Convoluted ones can collect debris in them to ,resulting in unpleasent
smells.A better piece of hose can be obtained at a boat/yacht chandlery,complete with stainless clips..Hope this helps ..
0 -
Had a 2009 Sundance which had a rigid pipe and a tank tap you could probably retro fit one of these. The Bessacarr we replaced it with had a flexible pipe which had to be replaced twice in four years. Cak tanks sell a very robust replacement with a smooth
internal bore by the metre.0 -
CAK Tanks supply smooth bored helicoil hose in several sizes through their online store, or they will be at
the NEC Show in October. They also supply matching taps and adapters for connecting to rigid waste systems.0
