Travelling with water in the fresh water tank
RD02
RD02 Forum Participant Posts: 2 Participant
edited February 2016 in Motorhomes #1
I am new to motorhoming after 30 years of owning a caravan.
Is it wise to travel with some fresh water in the tank of my Auto-sleeper Broadway?
«1
    Tinwheeler Forum Participant Trusted Posts: 24,315
    edited February 2016 #2
    We have an AS Suffolk and nearly always have water in the tank when we travel. A tankful lasts us at least 3 days and we don't throw out any unused when moving on to the next site. We will, though, usually drain the waste tank on leaving a site - especially
    if that site has a good MH disposal point. You will find that some sites have good service points and some hopeless ones.
  • ABM
    edited February 2016 #3
    Oh  dear,  R2D2,Surprised  be  prepared  for  the  onslaught  !!
    Somewhere  in  the  region  of  60 / 40  split  on  this  subject  within  those  who  have  expressed  a  preference  !!
    My  m/van  has  the  fresh   ( drinking ) water  tank  sterilised  with  Puriclean  or  similar  before  the  season  starts,  and  again  at  the  seasons  end --  if  any !
    In  between  these  days  my  m/home  has  at  least  1/2  tank  of  fresh  water,  so  the  motor  is  ready  for  use  at  the  drop  of  a  hat !!  I've  been  m/vanning since  '79  &  see  no  reason  to  alter  my  habits  .  Must  say  tho  others  will  disagree,  so  try  both  methods  &  Bob's  your  Auntie  or  some  such  !!Happy
    edited February 2016 #4
    That reminds me, ABM. We generally fill our tank at home before setting off to save hassle on site.
    When you consider the wild camping aspect of MHing (shudder), they certainly can't refill at every stop so must travel with water in the tank.
  • rogher
    edited February 2016 #5
    Welcome to the freedom of motorhoming, RD.
    It’s prudent, as well as convenient, to take enough water for the journey. “The journey” means “until you next expect to be able to top up”. You have limited payload, so I wouldn’t fill any more than necessary.
    edited February 2016 #6
  • TanyaandMick
    TanyaandMick Forum Participant Posts: 139 Participant
    edited February 2016 #7
    We typically travel with a full tank.
  • kenexton
    edited February 2016 #8
    short answer....yes, its fine.
    we travel with what ever is in the tank....anything from over 100 ltr to not a lot......
    you have a motorhome which is designed to be used and driven with water in it....and you never know where you might pull in.....
    Write your comments here...ditto except that during the Winter period I do empty the tank completely if the MH is not in use.We have a CAK under slung water tank and I have fitted a thermostatically controlled tank heater to the fresh water tank to prevent
    freezing when out in the Winter-it is switched off when the MH is garaged so I drain down in case of cold snaps, like the one we are experiencing as I type.
    edited February 2016 #9
    I've no experience of these matters, but I would have thought that a full tank would affect stability less than a half full one as it would limit the ability for the amount of weight to slop around. other than the weight penalty, what other disadvantages
    would there be?
  • BlueVanMan
    100 Comments Name Dropper
    edited February 2016 #10
    This topic has been covered more fully elsewhere. You should and legally MUST operate your vehicle within its payload limits and these limits prescribe a loading for each axle. There are articles and advice elsewhere about how you check axle loads etc on
    a weighbridge. Assuming that travelling with a full tank will not compromise your overall loading it depends what you are doing and where you are going. If you are travelling a short distance between sites there may be little point in partially or fully emptying
    your tank. At the end of your "holiday"  if your van is going into storage for a while you might as well drain the tank. If you are using aires (abroad mainly) etc and you dont have a  ready supply at your destination you may choose to travel full. You will
    soon through experience become adept at working out your water useage/amount in tank which is useful because most water guages are not accurate and some very unreliable. We always drain grey water when we can partially because our grey tank is small compared
    to the fresh tank.
    In summary.
    Gear your water load to your needs at the next stop
    Watch your payload
    Dont rely completely on your water tank guages.
  • JD6620
    JD6620 Forum Participant Posts: 202 Participant
    edited February 2016 #11
    We generally travel with enough water for our needs until we arrive at our site where we can then fill up.  I don't see the need to travel with more water than you will need as each litre weighs one kilo, and if your light on payload that can make a difference.
     I've never noticed any stability issues with however much water i have had on board.  Water tanks are slung low under the van so would have limited affect on stability.
  • EJB986
    edited February 2016 #12
    We always travel full and each year at the MOT all straps and other underneath fittings are carefully checked!
  • rogher
    edited February 2016 #13
    It’s not unreasonable to think about “all that water sloshing about” but no one seems to be bothered about it when it’s fuel in their tank.
    If your payload will allow it, fill your water to the brim but allow for less mpg as a consequence.
    edited February 2016 #14
  • rogher
    edited February 2016 #15
    I think you’ve been misled by salespeople, BB. I don’t think they do much more than build tanks to suit the shape that happens to be available. I’d like to think there was more science behind the designs but there’s little evidence of it elsewhere so I don’t
    suppose it’s been applied to tanks which are out of sight.
  • brue
    edited February 2016 #16
    We travel with a full tank but only do this because the payload is ok, we get a reasonable mpg and no sloshing!Wink
    DavidKlyne Club Member Posts: 14,783
    edited February 2016 #17
    We always fill up the tank before leaving home. Its never completely full because we park the motorhome on a slight slope but its best part of full. When we are returning home we let the volume run down but don't refill. Always travel with waste water tanks
    empty. My motorhome seems to return a pretty consistant 25 mpg regardless of load.
  • EJB986
    edited February 2016 #18
    As an after thought the Thetford toilet manual suggests that the header tank should be empty when travelling.
    In over 50 years ours have never come to any harm as it too is more or less always full!!
    edited February 2016 #19
  • QFour
    edited February 2016 #20
    We always travel with a full tank. You never know when you might find another tap. We also have a couple of universal hosepipes ( Watering Cans ) for when we do. Best spot for filling up so far was Buxton. It's just a fountain that pours water out. Lot of
    people filling water bottles so I just filled a few watering cans and walked over the road Laughing
  • kenexton
    edited February 2016 #21
    Be careful not to habitually "brim" the tank as I did in the early days with the current  MH. In doing so I ruined the sensor in the tank.Water got over the top of the unit and it stopped working as I had filled it until I had  water running out of the tank
    overflows.We had to take off the tank to replace the unit-since then my OH watches as we approach 100% and tells me when to shut off the tap.No problems since then but a costly lesson learned.
  • QFour
    edited February 2016 #22
    Seems a bit daft having a water sensor that is affected by water Frown
  • 740man
    740man Forum Participant Posts: 5 Participant
    edited February 2016 #23
    Do people know how much water weighs seams a bit daft to me when you have water on site which takes about 10 min to fill the tank
  • ABM
    edited February 2016 #24
    But  many  of  us  are  regularly  pitched  "Off  Site"  and  I  seldom  feel  the  urge  to  top  up  my  tanks  from  the  stream,  whose   crisp,  clear  water  is  running  over  that  dead,  maggot  ridden    sheep  100  yards  away !
    edited February 2016 #25
  • MichaelT
    edited February 2016 #26
    Write your comments here...I think it is more imprtant when you are travelling but are not sure if there will be water on site when you arrive such as abroad and going to an Aire etc.  also a good idea to have some in case of emergency and you need to cook,
    wash up etc.
  • ADP1963
    edited February 2016 #27
    Write your comments here... I must be lucky as I have filled my tank untill the overflow has come into action many times with no trouble.
  • Graydjames
    Graydjames Forum Participant Posts: 471 Participant
    edited February 2016 #28
    I think most people know. Why is it daft? Because of fuel consumption - a fraction of a mile per gallon for a the average half full tank? Maybe half a mile per gallon tops for the avergae full tank. Do you worry when you have an extra person on board in your car or motorhome? I don't and I like to know I always have some water on board. For me it's daft not to.
  • ABM
    edited February 2016 #29
    Well RDO2,  I did  say  "Be  prepared  for  the  onslaught"  didn't  I
    One  of  the  very  few  times  I  can  recall  being  100%  right  on  this  Forum  !!Wink
    Brian   { gigglling  merrily  --  without  aid  of  any  booze  as  well  !! Happy }
  • royandsharont
    edited February 2016 #30
    I generally travel with mine full, 110L or 110kg, at the start of a tour then various quantities depending on how easy I think it will be to access the water at the next place. I empty it when I am back at home again. Any difference in fuel consumption I think will be almost unrecognisable and I have never noticed any reduced stability from the water moving around. I always fill to overflowing as well as it is easy to know that way when doing it yourself and have not had any sensor problems. Regards, Roy
  • Aspenshaw
    edited February 2016 #31
    Hymer, and an increasing number of manufacturers, will recommend a 20l maximum when travelling 'for safety' although if I filled the fresh water tank to the full on my Hymer, my van would be overweight. My tank has a plug that can be set to limit the level
    to 20l. Somewhere in the recess of my degrading mind is a memory that all manufacturers now have to put in some system to provide for a travelling limit of 20l - even though there is no law to say you must travel with no more than 20l.
    Ask yourself why would you need more than 20l. If you do, such as when camping off sites, then providing you have the payload, can cover the modest increase in fuel costs, and are satisfied your stability on the road is unaffected [120l of water on a tank
    between axles is safer than 120l in a locker under a bench seat on one side], then put in as much as you want.
