Hot water - not hot
Tyre Fitter
Tyre Fitter Forum Participant Posts: 21 Participant
edited January 2016 in Parts & Accessories #1
Im having a new kitchen fitted as home this week  the OH is going to cook meals in the caravan on the drive,,I've just filled the onboard tank after drawing for winter & the hot water isn't hot only warm,,am I doing something wrong or do I need to let it
run a while.
my van is a 2014 sterling Eccles.
Andy
  • rogher
    edited January 2016 #2
    Maybe you’re a little impatient. It will take a little while to heat up, especially if the water is cold to start with. Is it hot now? Are you heating with gas or just electric?
  • Tyre Fitter
    edited January 2016 #3
    it's working ok now,,I'm use ehu.
    Andy
  • rogher
    edited January 2016 #4
    Electric will take far longer than gas and, at home, may not be saving you anything in cost at all.
    edited January 2016 #5
  • Tyre Fitter
    edited January 2016 #6
    if I turn gas on will it automatically switch hot water from electric to gas or do I have to alter settings on the Aldi control panel.
    Andy
    edited January 2016 #7
    Andy
    If it's similar to my hot water (Truma, not Aldi) then both gas & electric work in tandem
    edited January 2016 #8
    edited January 2016 #9
    As you have the Alde, the water should heat up in less than 30 minutes, quicker using gas.
    How many KW did you set the electricity to?
    As well as heating the water, was it trying to heat the van too?  If so, heating the water would take longer.
    If you want to use gas instead of electricity, you need to select gas (the little flame) on the controller AND deselect electricity (no kw number showing), otherwise it will use electricity in preference to gas.
    If you want to heat only water, set the van temperature to lower than the ambient, and select the water boost  if you want extra-hot water. It will boost the water temp for 30 minutes (great for showers) and cut off the heating pump temporarily.
    edited January 2016 #10
    With the Alde, if you give it both gas and electricity it will always use electricity first and only add in the gas if necessary.
    As things warm up it will automatically cut down the gas use, cutting it out altogether in the end, and use just electricity to maintain the temperature.
    It's quite a clever system.
    edited January 2016 #11
    It sounds complicated ...... more so than my Truma
    edited January 2016 #12
    Not really, it does it all automatically, you just need to choose the settings you want.
    There is an "urban myth" that the Alde is complicated to use, so much so that a lot of people never try to use the many excellent features.
    Basically.....people, mainly we men, think reading and following instructions is beneath them, so lose patience.
    edited January 2016 #13
     .....Basically.....people, mainly we men, think reading and following instructions is beneath them, so lose patience.
    When all else fails ..... read the instructions Cool
    edited January 2016 #14
    Actally, the older Alde is a nightmare to programme and I had to consult my abbreviated instructions every time. That's why they switched to the newer control panel which I believe is more intuitive.
    edited January 2016 #15
    We have "an older Alde", my wife has no problem operating/setting the controller.............
    On the basis that it is enough that one of us knows how to do it, and since it saves me reading the instructions, I leave it to her!
