Electric bike battery recharging on French hook up
Flutel
Flutel Forum Participant Posts: 113 Participant
I'm taking an electric bike to France. Will it recharge ok on the French hook up? Anyone have any experience?
    edited August 2016 #2
    In theory 230 volt as here and same frequency. No idea what you might find on some site EHU bollards in actuality though. It will be intersting to see if anyone has had any problems.
    edited August 2016 #3
    Hook your van up to the bollard and plug your battery charger into one of the socket outlets on the van. The power supply is exactly the same.
    Most French site EHUs take the normal blue three pin plug but occasionally they have a two pin socket and you will need an adapter which you can buy here before you go.
  • Flutel
    edited August 2016 #4
    Thanks for that.  I have the adaptor - so - bring it on! Happy
  • JimE
    JimE Club Member Posts: 462
    100 Likes 100 Comments Name Dropper Photogenic
    edited August 2016 #5
    I use two battery chargers at the same time using a Y-splitter and a UK multiplug from my MH's EHU lead which remains attached to the MH.  Not had any problems with supply tripping - we're just careful what appliances we use.
  • Bective
    Bective Forum Participant Posts: 2 Participant
    edited August 2016 #6
    Not long back from France and at times both our battery's were charging at the same time in the awning via extension cable from van outlet with no problem
  • H B Watson
    edited August 2016 #7
    Even on a 3 Amp bollard there should be no issue with charging an ebike, it should pull only a few tenths of an Amp.
  • EJB986
    edited August 2016 #8
    I intended to answer that French electric is the same as UK electric but thought my comment might be taken in the wrong way....however....it is the same!!!!SurprisedHappyWinking
