M/home power socket to 13 amp adaptor
teddyedward
teddyedward Forum Participant Posts: 11 Participant
edited March 2016 in Motorhomes #1
For years I have been putting up with a flex which is far too short on the above item. When the plug is in the extension lead socket I have to stand it on two inverted buckets and then cover it to make it high enough and waterproof. I have looked for a lead
with a longer flex without success. Has anyone seen any adaptor with a longer lead that will run under my m/home or do I have to dismantle and put on a new length of flex?
  • QFour
    edited March 2016 #2
    ? Glad you know what you mean ...
    edited March 2016 #3
    Trying to "re-engineer" your question. Do you mean the adaptor that enables your motorhome EHU lead with blue sockets to connect to a 13 amp socket at home? This is a 13 amp domestic plug top, short lead and IEC blue connector and if your house 13 amp socket
    is outdoors then I understand the problem. In which case, why not make your own lead with a waterproof 13 amp plug? Usually the socket would be in your garage or indoors.
  • EJB986
    edited March 2016 #4
    My adaptors (UK and European) have 12 inch cables which is long enough......the socket is in the garage!?
  • Fozzie
    Fozzie Club Member Posts: 635
    edited March 2016 #5
    Caravan Plug To 13 Amp Socket Mains AdapterIs this what you are referring to.As your post was confusing.
    If not then you probably have a faulty bucket.
  • Fozzie
    edited March 2016 #6
    Or this?Mains Adapter - 13 Amp Plug To Caravan Mains Socket
    edited March 2016 #7
    We await the OP's answer with bated breath. I assume that's exactly what he means but maybe the socket outlet is outdoors so the connector could be hanging down and sitting in a puddle. They are not waterproof only splash proof.
    edited March 2016 #8
    I think the original poster is using a normal household 13A extension lead to go out to the motor-home, and then plugging the 12" adaptor in between that and the socket on the motor-home.
    Many people I know plug the 12" adaptor lead into an indoor socket in the house/garage/shed and link it using the cable that they would use on site to reach the caravan/motor home.
    Perhaps the original poster always stays off-grid and does not have a "blue plug" lead?
  • teddyedward
    edited March 2016 #9
    Thankks for your thoughts - my motorhome is about 60 yards from the house so I have to run a long extension down there. I shall probably dismantle the adaptor and replace the short lead with a longer one rather than connect with an ordinary orange lead first
    as this is a bit cumbersome along with an extension lead. Thanks.
    edited March 2016 #10
    The Club will not allow one to use two standard cables joined together but what one does with one's own 90 feet is a different matter. The blue plugs and sockets are not entirely waterproof but a 13 amp plug is a lot less so!
  • thebroons
    thebroons Forum Participant Posts: 165 Participant
    edited March 2016 #11
    Would it be feasible to fit an outdoor waterproof socket to use for plugging the 3 pin ehu extension.
    edited March 2016 #12
    Indeed it would!  Best long term solution.
    Without getting involved in the complex regulations it is something that "a competent person" should be capable of doing. The official advice, however, is always to employ an electrician. They may seem expensive but are cheaper than an undertaker.
