2004 Lunar Clubman Power Points
Stemar
Stemar Forum Participant Posts: 7 Participant
edited July 2016 in Caravans #1
I want to fit a USB charger to our caravan and the easiest way would seem to be to tap into the supply to the 12v/ TV antenna socket. This is a silver & black socket which shares a black surround/back box with a 240v power point.
There are no visible screws or other fittings, so before I go down the brute force route, with associated unintended consequences, can anyone tell me how to get the back box out so I can tap into the wiring?
The nearby 12v switch panel has no shortage of +12v wires, but the only earth return is way too small.
Thanks
  • KENNYG
    KENNYG Forum Participant Posts: 215 Participant
    edited July 2016 #2
    Why not replace  a 240 volt socket with built in usb sockets probably pick up for about 10 pounds.
  • Discoil
    Discoil Forum Participant Posts: 19 Participant
    edited July 2016 #3
    The surround/bezel around the sockets come off to reveal fixing screws.
  • iffajobsworthdoing
    iffajobsworthdoing Club Member Posts: 94
    edited July 2016 #4
    Treat it carefully you may well find it is brittle, start with a very small electricians screwdriver.
  • Stemar
    edited July 2016 #5
    First I have to get the damn things out... Also, There are two power points, a TV point and switches for the mains water heater and heating all matching and in a style I've never seen before. The boss would not be impressed if they don't match afterwards...
  • Stemar
    edited July 2016 #6
    Ah, it's the silver bit that's the bezel that unclips. Fortunately, I discovered that before getting to rough with the black bit :)
    Thanks
