Trumatic heater problems
johndailey
The Truma heater in my caravan works pefectly on hook up. Using it on gas is another matter. I have had it looked at twice and assured that it ignites. Yesterday I even changed gas bottles in desparation. I have done the obvious and checked that gas is running
through the system by using the cooker. Could somebody help please?
  • Bakers2
    Bakers2 Forum Participant Trusted Posts: 8,680
    edited May 2016 #2
    Sorry can't help, but acknowledging your post which hopefully means it'll be seen. ?
  • johndailey
    edited May 2016 #3
    Thank you Bakers 2. Very nice of you to do so.
  • IanH
    IanH Club Member Posts: 4,708
    edited May 2016 #4
    Have you actually seen it working on gas after the person who looked at it twice said it was fine?
    Do you hold down the control knob for a while after pressing the ignitor?
    There is a sensor (a thermo-couple) that must be within the flame for a few seconds before the fire will stay lit (it's a safety thing).
    Sometimes the thermo-couple gets out of position and isn't sat in the flame properly.
    Can you see a spark when you press the ignitor?
    Can you hear the ignotor clicking when you press it?
  • johnathome
    edited May 2016 #5
    have you checked if your isolation valve is in the on position.
    usually each appliance has its own isolation valve.
  • IanH
    edited May 2016 #6
    They are under the sink on our caravan.....
  • johndailey
    edited May 2016 #7
    Ian, I did get it to work on one occasion after the mechanic looked at it. I carry out the procedure as you recommend.I cannot remember hearing the ignitor clicking.
    Johnathome. The isolation valve should be open as I did manage to light it on one occasion.
    Thanks for the suggestions guys. If and when I get it working, I will podt on here and let you know what the problem(s) are.
  • IanH
    edited May 2016 #8
    If you cannot hear the igniter clicking then it might be faulty or it might need a new battery.
    The igniter unit clips to the front of the heater, behind the front cover (I only know because ours fell off recently!).
    This is the item
    here
    . The 15th and 16th item down the page.
    Some of them take a battery and some connect to the caravan 12v system (depends on the age of the van, I think).
    Might be worth having a look at this - a battery on its way out might work sometimes and not others.
  • johndailey
    edited May 2016 #9
    Ian. There is no battery on this model. I believe it is a Pissa type heater.
  • IanH
    edited May 2016 #10
    John, I think maybe you mean a piezo type of igniter.
    They are also available fom the company in the previous link. Also on Ebay, no doubt.
  • johndailey
    edited May 2016 #11
    Ian. Thanks for the correction. The way that I spelt it sounded like something you could eat - not eat!
  • johndailey
    edited May 2016 #12
    Correction - Eat not heat!
