Swift group battery charger fault
Options
dpe
dpe Forum Participant Posts: 8 Participant
I have a 2008 Sterling fitted with a Nordelettronica NE143-P charger which has given up. Reading the internet this is a very common problem so phoned my local dealer who quoted £250 to fit a new one. Did a little research and found a Sargent PX300 that was
said to replace most Nordelettronica chargers at a cost of £110. I place an order and true enough it took 15mins to fit and works as it should, saving £140 from what the dealer quoted. The Nordelettronica power lead plug is the same and Sargent supply a lead
to fit the output connection simple plug and play took longer to screw it to the wall than wiring it up. You don't need any DIY knowlage exept how to use a screw driver.
https://sargentltd.co.uk/shop/product/px300_charger/152
Welcome!
Welcome!
