13 pin connector problem
Derekbown
Forum Participant Posts: 8 Participant
In August Monthly Edition a fellow member was having trouble connecting the 13 pin plug to socket.
I have had the same problem and I have come up with a costless tool for re-aligning the plug.
This is made from a 25mm x 70mm plastic water pipe with a 5mmx 25mm slit in 1 side. Insert this in the plug and twist to relocate pins in alignment.
N.B I think that 25mm pipe is a toilet overflow pipe.
I hope that this helps. Del
