2015 Lunar Delta TI - Onboard Water Tank.
Dturr
Dturr Forum Participant Posts: 2 Participant
My onboard tank shows 3/4 full on the controller yet the tank is empty. I have;
1. Emptied the tank and tried to refill but the tank does not take much water from the aqua roll before showing full.
2. Disconnected the cables near the tank the re connected but no change.
3. Replaced the pump in the aqua roll.
Can ayone offer any more ideas before I contact my dealer, as I on a seasonal pitch then a return to base is difficult.
In recent weeks we required a repair to the dometic loo which deposited pink fluid in the well under the cassette and a new board in the Alde 3020 heating !
Thanks.
    KjellNN Club Member Posts: 9,026
    edited September 2016 #2
    You could try cleaning the probes that measure the water level in the tank.
    edited September 2016 #3
  • CBRBlackbird
    CBRBlackbird Forum Participant Posts: 184 Participant
    edited November 2016 #4
    The water level on my 2015 Delta had always been a bit erratic but them really went haywire.
    I've just had the level probe assembly replaced (under warranty) and now all works OK - in fact seems better than when the van was new.
    Appears to be a very comman problems and was replaced under warranty without any arguement.
  • crusader
    edited November 2016 #5
    I have the same problem with our 2016 Delta it appears to be the sensor switch, Lunar are very aware of the problem just very slow to react
