Travelling with fresh water in winter
D40David
D40David Forum Participant Posts: 39 Participant
edited September 2016 in Motorhomes #1
I have a 2016 Autosleeper Kemerton which has tank blankets which I assume will stop the tanks freezing in winter. What about when travelling to sites as the tanks are exposed to the elements. I do like to travel with some water just in case!
    Tinwheeler Forum Participant Trusted Posts: 24,172
    edited September 2016 #2
    If you're travelling the water will move and is very unlikely to freeze in this country.
    peedee Club Member Posts: 9,960
    edited September 2016 #3
    and if you have tank heaters switch them on.
    edited September 2016 #4
  • bobash
    bobash Forum Participant Posts: 33 Participant
    edited September 2016 #5
    Write your comments here...You can't operate the tank heaters on the move.
  • Takethedogalong
    Takethedogalong Forum Participant Trusted Posts: 18,145
    edited September 2016 #6
    We toured with our AS throughout last Winter and Winter previous, including temps down to -12c. I can't recall us having any issues. Can only assume well lagged or residual heat kept things ok. We always drain down when getting home though, if MH is having
    time off. Never had issues with onboard caravan tank either, although we didn't travel with that with water in, but it never froze on site. Unlike the other van with exterior water barrel. Pass the hairdryer please!Happy
    edited September 2016 #7
    edited September 2016 #8
    Surely that depends on how they are wired on the motorhome. I have not yet found it cold enough to run mine but I do have a 12v supply available with the ignition on although I am aware not all motorhomes do.
